I’ve a RB951Ui-2Hnd which I purchased a few months ago. I had a play but the config seemed beyond me so I put it away for another day.
Tonight I tried to connect again with no success.
I’ve reset the unit back to factory settings (paperclip to the reset switch next to the power in) but I don’t seem to be able to connect.
Using a patch cable to port 1 and an xp laptop, the pc reports that the local area connection is unplugged.
I’m getting a loop of strangled\double beep code, and the pc try’s to connect again.
The MikroTik wifi hotspot is showing but I’m not able to connect. I’m not being asked for a new password and the pc tries to aquire a network address, but come up ‘unconnected’.
I’ll try the other ports and see how I get on. I did try reset it several times without success last time but have managed to reset the unit before.
Stupidly I realised after posting that I was using the wrong power adaptor and have now swapped to the correct one. The unit powers up and I get a wifi signal so hopefully it’s OK. Still not able to log in or get a connection so I wondered if perhaps the wrong power may have corrupted the firmware - is it possible to reload it without being able to log into the unit, perhaps via the USB socket.
I connected via a different client on Lan port #2 and gained access. I had to reset the WIFI pw for some reason but once reset I could connect via wifi.
I get the feeling that some of the documentation needs an update.
