unable to connect to userman webpage when hotspot enabled
ok, a slight problem which i believe is a misconfiguration on my part.
But im currently running a hotspot on routeros 3.23 and everything is going ok, but when I enable userman i am unable to access the interface via explorer unless i disable the hotspot, and when ever i reconfigure the hotspot im unable once again to access the userman webpage…
Is this something to do with re-direct/ Webcache configuration error?
I’ve tried reinstalling the router from start and following the correct procedures, but ever time i encounter the same problem.
Any idea guys?
Thanks in advance :smiley:
See this post
