Unable to connect to VPN server
Dear Team
I need some advice i have setup a VPN (MIkrotik Router) server which allow me to connect to all my remote router.via L2tp
All my client router is running dynamic Ip.
Now i am facing some problem to connect to the server
Please advice on this.
Regards
Balan
I am also unable to ping to any off the client router
can you provide more details about your issue. Draw topology, explain who is establishing VPN to where… Its bit odd to expect help without any explanation.
Guys
I have the attachment the simple diagram as request and also the the conflagration file.
Please assist
Regards
Balan
Whoah, your configuration is really confusing. There are 30+ rules of masquerade with unknown interface. You have all servers running on your router ( PPTP, SSTP, L2TP, OVPN). Your ether12 has public and private address. I have not seen logical masquerade. Sorry, i am not able to provide any help. I can only suggest you to follow this tutorial, so at the end you may get a result you are looking for.
http://wiki.mikrotik.com/wiki/PPTP_Server_With_Profile
Thanks for the Reply
This was done by previous engineer,I just take over the Job
I am planning to setup a new vpn server as my diagram.
Please advice how can i do it
Regards
Balan
you can check out the following documents:
http://wiki.mikrotik.com/wiki/Manual:Interface/L2TP
http://wiki.mikrotik.com/wiki/Manual:BCP_bridging_(PPP_tunnel_bridging)
