I’m having troubles with connecting to wifi 2.4GHz on hap ax^3. I set my configuration with quick set, added few changes (container, IP pool ect). The config worked for long time but today it stopped. I tried few restarts or change the security from WPA/WPA2 to different options. Here is my config:
/container mounts
add dst=/opt/adguardhome/work name=adguard-work src=\
/usb1/adguard-home/opt/adguardhome/work
add dst=/opt/adguardhome/conf name=adguard-conf src=\
/usb1/adguard-home/opt/adguardhome/conf
add admin-mac=F4:EE:57:86:37:FF auto-mac=no comment=defconf name=bridge
add name=docker
set [ find default-name=ether1 ] mac-address=18:AA:F7:FD:41:4F
/interface wifi
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=10min-cac \
.width=20/40/80mhz configuration.mode=ap .ssid=ssid5 disabled=no \
security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=10min-cac \
.width=20/40mhz configuration.mode=ap .ssid=ssid24 disabled=no \
security.authentication-types=wpa-psk,wpa2-psk .ft=yes .ft-over-ds=yes
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-net user=xxxxx
/interface veth
add address=192.168.34.2/24 gateway=192.168.34.1 gateway6="" name=ads
/disk
set usb1 media-interface=bridge media-sharing=yes smb-sharing=yes
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=default-dhcp ranges=192.168.50.10-192.168.50.254
add address-pool=default-dhcp interface=bridge name=defconf
/container
add interface=ads logging=yes mounts=adguard-work,adguard-conf root-dir=\
/usb1/adguard-home start-on-boot=yes workdir=/opt/adguardhome/work
/container config
set registry-url=https://registry-1.docker.io/ tmpdir=/usb1/tmp
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add bridge=docker interface=ads
add address=192.168.50.1/24 comment=defconf interface=bridge network=192.168.50.0
add address=192.168.34.1/24 interface=docker network=192.168.34.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.50.233 client-id=1:cc:5f:f4:ef:8f:8c comment=pc mac-address=\
BB:5F:F4:EF:8F:8C server=defconf
add address=192.168.50.0/24 comment=defconf dns-server=192.168.34.2 gateway=\
192.168.50.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.50.1 comment=defconf name=router.local type=A
add address=192.168.34.1 name=adguard.local type=A
add action=accept chain=input comment="defconf: accept established,related,untracked" \
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
out,none out-interface-list=WAN
add action=masquerade chain=srcnat out-interface=pppoe-net
add action=masquerade chain=srcnat src-address=192.168.34.0/24
add gateway=pppoe-net
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" dst-port=\
33434-33534 protocol=udp
"defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp \
src-address=fe80::/10
protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" \
"defconf: drop everything else not coming from LAN" in-interface-list=!LAN
invalid
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" \
src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" \
dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=\
equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 \
protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
ipsec-esp
/system clock
set time-zone-name=Europe/Warsaw
/system note
set show-at-login=no
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system routerboard wps-button
set enabled=yes on-event=wps-accept
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\r\
\n :if ([system leds settings get all-leds-off] = \"never\") do={\r\
\n /system leds settings set all-leds-off=immediate \r\
\n } else={\r\
\n /system leds settings set all-leds-off=never \r\
\n }\r\
\n "
add comment=defconf dont-require-permissions=no name=wps-accept owner=*sys policy=\
\n :foreach iface in=[/interface/wifi find where (configuration.mode=\"ap\" && d\
isabled=no)] do={\r\
\n /interface/wifi wps-push-button \$iface;}\r\
\n "
/tool mac-server
/tool mac-server mac-winbox
