I have an LtAP Mini with two SIMs inserted. SIM1 (up) is used purely for receiving SMS and SIM2 (down) is used for data
By default the LtAP is running using SIM1 (up). When it receives an SMS it switches to SIM2 (down/data) for a set amount of time before switching back to SIM1. This mostly works but deleting SMS doesn’t seem to work correctly and sometimes results in a temporary loop that switches from SIM1 → SIM2 → SIM1 a number of times.
If I send an SMS to SIM1 that doesn’t match the script format, it stays in the SMS inbox, but I am unable to delete it due to RouterOS not believing the interface is running.
The LtAP is running the latest firmware 6.43.4.
The interface doesn’t get marked as ‘RUNNING’
[admin@lte2] > /interface lte print detail
0 name="lte1" mtu=1500 mac-address=XX:XX:XX:00:00:00 pin="xxxx" apn-profiles=default network-mode=gsm,3g,lte
… but it shows as connected and is able to receive SMS:
[admin@lte2] > /interface lte info 0 once
pin-status: no password required
functionality: full
registration-status: registered
manufacturer: "MikroTik"
model: "R11e-LTE"
revision: "MikroTik_CP_2.160.000_v008"
current-operator: xx - UK
lac: 21090
current-cellid: xxxxxxx
access-technology: 3G HSDPS & HSUPA
imei: xxxxxxxxxxxxxxx
imsi: +CME ERROR: 10
uicc: xxxxxxxxxxxxxxxxxxxx
subscriber-number: +CME ERROR: 100
earfcn: 10661 (DL freq 2132.2Mhz)
rssi: -87dBm
The SMS inbox has messages:
[admin@lte2] > /tool sms inbox print
# PHONE TIMESTAMP MESSAGE
0 +44xxxxxxxxxx Nov/25/2018 10:30:37 GMT +0 Test4
… but I’m unable to delete them
[admin@lte2] > /tool sms inbox remove 0
failure: Interface not running!
Sending raw AT commands shows messages:
[admin@lte2] /interface lte> at-chat input="AT+CPMS=\?" lte1
output: +CPMS: ("SM"),("ME"),("SM")
OK
[admin@lte2] /interface lte> at-chat input="AT+CPMS=SM,ME,SM" lte1
output: +CPMS: 1,20,1,20,0,0
OK
… and I can delete them via AT commands:
[admin@lte2] /interface lte> at-chat input="AT+CMGD=\?" lte1
output: +CMGD: (1),(0-4)
OK
[admin@lte2] /interface lte> at-chat input="AT+CMGD=1" lte1
output: +MMSG: 0, 0
OK
+MMSG: 0, 0
… and they get deleted:
output: +CPMS: 0,20,0,20,0,0
OK
… but the SMS inbox still shows them until I reboot:
[admin@lte2] /interface lte> /tool sms inbox print
0 +447460079051 Nov/25/2018 10:30:37 GMT +0 Test4
Is this expected behaviour?
