Good morning.
I am trying to configure a hAP ac³ device with RouterOS v6.46.8 (long-term)
I would like to disable the wlan2 interface. I can do it perfectly from “WebFig → Wireless → wlan2 → Enabled → False”, but if I then make any changes from QuickSet (WISP AP), the “wlan2” interface is re-enabled.
On the other hand, it is very confusing that wlan1 interface cannot be selected in QuickSet (WISP AP), only wlan2 appears.
Kind regards.
