Hi, I just downloaded the dude 3.6, installed and started discovery, I turned win firewall off, I have few devices on my network that are online now, but the dude is unable to discover anything, anything at all.
any advice / help
much appreciated.
any advice / help
much appreciated.
Make sure that your devices are able to reply ping requests and that there´s no other firewall in the network filtering pings sent by The Dude.
just double checked all, there is no other firewall, and all devices are pingable…
I have used the dude before, in our office and it worked well, but here on this location it does not.
what can I check more? to make sore it works ?
I found out what the problem was, I had to change the settings of the bridge interface, where it says ARP : enabled, I changed this to ARP : proxy-arp after that it started working fine.
thanks.
now after following a video tutorial and also changing some settings on the arp section of the bridge, I’m able to see all devices connected by fisical ports, but wifi devices are not showing, I tried the arp option but that does not help, anybody knows why the dude does not show wifi devices by discovery ?
