unable to download 2.9.16
When I try to download 2.9.16 from MT site, I get following:
ERROR - File not found
We have logged this error and will correct the problem if it is a broken link.
Please go to our Main Page.
The same for 2.9.15. Only 2.9.14 seems to download fine. I’m the only one with tris problem? :slight_smile:
I am also having the same issue.
6:30 am EST. Both the US and Latvia are giving 404’s
[~/mikrotik]$ 8 > wget http://www.mikrotik.com/download/all_packages_2.9.16.zip
–06:40:14-- http://www.mikrotik.com/download/all_packages_2.9.16.zip
=> `all_packages_2.9.16.zip’
Resolving http://www.mikrotik.com… 159.148.147.196
Connecting to http://www.mikrotik.com|159.148.147.196|:80… connected.
HTTP request sent, awaiting response… 404 Not Found
06:40:14 ERROR 404: Not Found.
This is a RouterOS reseller in the US.. and they also do not have 16 on their site..
http://windstore.windwireless.net/index.php?pg=35
I did not a notice that there was some problem in .16 .. is there another problem in .16 ?
I am the same error too. Guess they are trying to fix something in .16 before it gets out of hand.
2.9.17 is on the download page; no changelog yet.
There is a changelog now. But very short one :slight_smile:
What’s new in 2.9.17:
*) fixed TCP SYN connection tracking timeouts;
I need to download the version 2.8.16. This is the last version i can use due to my licence.
can anyone help me where can i get it?
tanx
Thr version number has nothing to do with license. If your license expired, you cannot downgrade or upgrade anymore to any of versions
thats quite strange - what can i do with the errors in version 2.9.13? or will be tke MK for me useless, when my update-license is out of date?
You should buy license extention → email to sales@mikrotik.com
macgaiver: of course you are not corect - i can upgrade or downgrade to any version released bevor my expire-date.
Anyone knows where i can get the las version bevore 1.3.2006?
(version 2.9.15 or 2.9.16 i guess)
thanx
i dont want anything i have not paid for - but if i am buing a router and you make it useless as a router - major bug in routing protocol operation that was introduced in 2.9.13 - then i can´t use it as a router any more and if the sw does not fulfil its purpose…
but my question is: where can i download the version 2.9.15 and 2.9.16.
we do not provide older versions on our webpage for public download, you can write to support if you have specific request
thnx, i will try :slight_smile:
