since last stable update(i also tried with the new beta) i have some issue establishing IPSec Tunnel to NordVPN.
It tries to connect to the NordVPN peer and it stays on “message 1 sent” . After like half an hour the tunnel is established.
I enabled logging and this is showed up in the logs
Before the last stable update the tunnel was working without any issue.
