Have you used /ip dhcp-server setup command to configure DHCP server?
Remove DHCP configuration and use the command, if you configured DHCP server manually.
Make sure proper address is configured on interface, where DHCP server is configured.
Thanks for your reply Sergejs!
I didn’t have any problems getting IP addresses on my regular ethernet, it was just the wlan.
I found out what the problem was.
When i looked the webadmin page I observed at the Interfaces page there was a check-box at the bridged column. It wasn’t checked so i clicked that check-box and now everything is working!
