Currently I’m working out howto get everything working in Mikrotik land. Next to my RB5009 (which has a real basic setup for now) I also just bought an AX2. It will do its work as an AP and Switch on all 5 ports.
I created a VLAN (ID 200) on the RB5009 and the same VLAN (ID 200) on the AX2. On the RB5009 a cable is connected from ETH7 to ETH2 on the AX2.
In the bridge hosts table I do see that they somehow see each other (although on the router it is marked with DE and on the AP with D) But creating an address on the RB5009 and on the AX2 and try to ping each other does not work. DHCP also doesn’t seem to work.
Been trying for hours, but I cant seem to figure out the issue.
My RB5009 config:
# 2024-02-11 09:21:09 by RouterOS 7.13.4
# software id = *****
# model = RB5009UG+S+
# serial number = *****
add arp=proxy-arp ingress-filtering=no name=bridge-local vlan-filtering=yes
set [ find default-name=ether1 ] disabled=yes l2mtu=1568
set [ find default-name=ether2 ] l2mtu=1568
set [ find default-name=ether3 ] disabled=yes l2mtu=1568
set [ find default-name=ether4 ] l2mtu=1568
set [ find default-name=ether5 ] l2mtu=1568
set [ find default-name=ether6 ] l2mtu=1568
set [ find default-name=ether7 ] l2mtu=1568
set [ find default-name=ether8 ] arp=proxy-arp l2mtu=1598 loop-protect=off
set [ find default-name=sfp-sfpplus1 ] disabled=yes
/interface vlan
add interface=ether8 loop-protect=off name=vlan1.6 vlan-id=6
add interface=bridge-local name=vlan200 vlan-id=200
/interface pppoe-client
add add-default-route=yes allow=pap disabled=no interface=vlan1.6 \
keepalive-timeout=20 max-mru=1500 max-mtu=1500 name=pppoe-client-kpn \
user=----REMOVED---
add comment="All LAN interfaces" name=all_lan_interfaces
add name=local-pool ranges=192.168.0.1-192.168.0.100
add name=extovpn-pool ranges=192.168.10.1-192.168.10.5
add name=wifi_pool ranges=192.168.1.1-192.168.1.100
add address-pool=local-pool interface=bridge-local name=server1
add address-pool=wifi_pool interface=vlan200 name=wifi_dhcp
/ppp profile
set *0 only-one=yes use-compression=yes use-ipv6=no use-upnp=no
set *FFFFFFFE use-ipv6=no
/routing bgp template
set default disabled=yes routing-table=main
add bridge=bridge-local interface=ether1
add bridge=bridge-local interface=ether2
add bridge=bridge-local interface=ether3
add bridge=bridge-local interface=ether4
add bridge=bridge-local interface=ether5
add bridge=bridge-local interface=ether6
add bridge=bridge-local interface=ether7
/interface bridge vlan
add bridge=bridge-local tagged=ether7 vlan-ids=200
add interface=bridge-local list=all_lan_interfaces
add interface=ether1 list=all_lan_interfaces
add interface=ether2 list=all_lan_interfaces
add interface=ether3 list=all_lan_interfaces
add interface=ether4 list=all_lan_interfaces
add interface=ether6 list=all_lan_interfaces
add interface=ether7 list=all_lan_interfaces
add interface=vlan200 list=all_lan_interfaces
add address=192.168.0.254/24 interface=bridge-local network=192.168.0.0
add address=192.168.1.254/24 interface=vlan200 network=192.168.1.0
/ip dhcp-server config
set store-leases-disk=15m
/ip dhcp-server lease
--REMOVED--
add address=192.168.0.0/24 dns-server=192.168.0.254 domain=intranet gateway=\
192.168.0.254
add address=192.168.1.0/24 dns-server=192.168.1.254 domain=intranet gateway=\
192.168.1.254 netmask=24
set allow-remote-requests=yes cache-max-ttl=1d servers=\
94.247.43.254,94.16.114.254
/ip firewall address-list
add address=192.168.0.0/24 list=allowed_to_router
add address=192.168.1.0/24 list=allowed_to_router
add address=0.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=172.16.0.0/12 comment=RFC6890 list=not_in_internet
add address=192.168.0.0/16 comment=RFC6890 list=not_in_internet
add address=10.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=169.254.0.0/16 comment=RFC6890 list=not_in_internet
add address=127.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=224.0.0.0/4 comment=Multicast list=not_in_internet
add address=198.18.0.0/15 comment=RFC6890 list=not_in_internet
add address=192.0.0.0/24 comment=RFC6890 list=not_in_internet
add address=192.0.2.0/24 comment=RFC6890 list=not_in_internet
add address=198.51.100.0/24 comment=RFC6890 list=not_in_internet
add address=203.0.113.0/24 comment=RFC6890 list=not_in_internet
add address=100.64.0.0/10 comment=RFC6890 list=not_in_internet
add address=240.0.0.0/4 comment=RFC6890 list=not_in_internet
add address=192.88.99.0/24 comment="6to4 relay Anycast [RFC 3068]" list=\
not_in_internet
add action=accept chain=input comment="related and established" \
connection-state=established,related log=yes log-prefix=aaa
add action=accept chain=input src-address-list=allowed_to_router
add action=fasttrack-connection chain=forward comment=FastTrack \
add action=accept chain=forward comment="Established, Related" \
add action=drop chain=forward comment="Drop invalid" connection-state=invalid \
log=yes log-prefix=invalid
"Drop tries to reach not public addresses from LAN" dst-address-list=\
not_in_internet in-interface=bridge-local log=yes log-prefix=\
!public_from_LAN out-interface=!bridge-local
"Drop incoming packets that are not NAT`ted" connection-nat-state=!dstnat \
connection-state=new in-interface=pppoe-client-kpn log=yes log-prefix=\
!NAT
add action=jump chain=forward comment="jump to ICMP filters" jump-target=icmp \
protocol=icmp
"Drop incoming from internet which is not public IP" in-interface=\
pppoe-client-kpn log=yes log-prefix=!public src-address-list=\
not_in_internet
"Drop packets from LAN that do not have LAN IP" in-interface=bridge-local \
log=yes log-prefix=LAN_!LAN src-address=!192.168.0.0/16
add action=drop chain=input comment="Explicit drop all" log=yes log-prefix=\
IPv4_DropAll
add action=accept chain=icmp comment="echo reply" icmp-options=0:0 protocol=\
icmp
add action=accept chain=icmp comment="net unreachable" icmp-options=3:0 \
protocol=icmp
add action=accept chain=icmp comment="host unreachable" icmp-options=3:1 \
protocol=icmp
add action=accept chain=icmp comment=\
"host unreachable fragmentation required" icmp-options=3:4 protocol=icmp
add action=accept chain=icmp comment="allow echo request" icmp-options=8:0 \
protocol=icmp
add action=accept chain=icmp comment="allow time exceed" icmp-options=11:0 \
protocol=icmp
add action=accept chain=icmp comment="allow parameter bad" icmp-options=12:0 \
protocol=icmp
add action=drop chain=icmp comment="deny all other types"
add action=masquerade chain=srcnat comment="Needed for internet" \
out-interface=pppoe-client-kpn src-address=192.168.0.0/24
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set winbox address=192.168.0.0/24
set api-ssl disabled=yes
/ip upnp
set show-dummy-rule=no
/ip upnp interfaces
add interface=bridge-local type=internal
add interface=pppoe-client-kpn type=external
/ipv6 firewall filter
add action=drop chain=input comment="Explicit drop all" in-interface=\
pppoe-client-kpn log=yes log-prefix=IPv6_DropAll_Input
add action=drop chain=forward comment="Explicit drop all" in-interface=\
pppoe-client-kpn log=yes log-prefix=IPv6_DropAll_Forward
/ipv6 nd
/system clock
set time-zone-name=Europe/Amsterdam
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
set allowed-interface-list=all_lan_interfaces
/tool mac-server ping
set enabled=no
My AP config:
# 2024-02-11 09:29:23 by RouterOS 7.13.4
# software id = ***
# model = C52iG-5HaxD2HaxD
add arp=proxy-arp ingress-filtering=no name=bridgeap1 port-cost-mode=short \
vlan-filtering=yes
set [ find default-name=ether1 ] poe-out=off
/interface vlan
add interface=bridgeap1 name=vlan200 vlan-id=200
add bridge=bridgeap1 interface=ether2
add bridge=bridgeap1 tagged=ether2 vlan-ids=200
add address=192.168.1.101/24 interface=vlan200 network=192.168.1.0
/ip dhcp-client
add action=accept chain=output
/system clock
/system note
Router bridge hosts:
AP bridge hosts:
