Unable to go over 200mbps on HEX
Hi all,
I have been using mikrotik for a while and pretty happy both personally and at my clients. We finally got gigabit fiber to my neighborhood I upgraded from a HEX lite to the HEX with 5 gigabit ports. Trouble is, whenever I run a speedtest (using either a web tool or the built-in Bandwidth Test), it gets to about 225mbps and the CPU goes to 100% and it won’t go past that. I realize that the hardware isn’t that powerful, but it still has gigabit ports so I figure it should at least get close to gigabit speeds.
Anyone else familiar with this?
What eats the cpu? Try to use fasttrack if you do not need queues.
I just implemented fasttrack and it made no difference. Here are some screenshots:
Speedtest-
http://puu.sh/r6vfO/d08cd56f24.png
Firewall Rules-
http://puu.sh/r6vh3/23bbdf03a2.png
From Mikrotik Wiki:
Fasttracked packets bypass firewall, connection tracking, simple queues, queue tree with parent=global, ip traffic-flow(restriction removed in 6.33), ip accounting, ipsec, hotspot universal client, vrf assignment, so it is up to administrator to make sure fasttrack does not interfere with other configuration;
Are you using any of these features?
With a default config, the HEX will pass 900mbps. 25~30 filters rules will slow you down to about 800. Mangle and queues will drop you even more.
if you can post your queue and firewall exports, we can get a better idea of what is bringing you do so much.
Nope, none of that was configured. This is just put of the box with the exception of 4 ports forwarded.
Not sure how to export, but here are screenshots.
Queues-
http://puu.sh/r6zKA/89ea616d55.png
http://puu.sh/r6zLt/5d7683ddcd.png
Firewall-
http://puu.sh/r6zMX/1f62205533.png
open the console and type…
/firewall export
/interface export
/queue export
copy/paste the output
[admin@MOB] > /queue export
sep/03/2016 16:51:55 by RouterOS 6.36.2
software id = 8K75-VWJ6
[admin@MOB] > /interface export
sep/03/2016 16:52:17 by RouterOS 6.36.2
add arp=proxy-arp name=bridge1
set [ find default-name=ether5 ] mac-address=E4:8D:8C:93:F8:A8 name=“ATT 1G”
speed=1Gbps
set [ find default-name=ether4 ] mac-address=E4:8D:8C:93:F8:A9 name=LAN
set [ find default-name=ether3 ] mac-address=E4:8D:8C:93:F8:AA master-port=
LAN name=ether3-slave-local
set [ find default-name=ether2 ] mac-address=E4:8D:8C:93:F8:AB master-port=
LAN name=ether4-slave-local
set [ find default-name=ether1 ] mac-address=E4:8D:8C:93:F8:AC master-port=
LAN name=ether5-slave-local
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
add bridge=bridge1 interface=LAN
/interface l2tp-server server
set enabled=yes ipsec-secret=1234 use-ipsec=yes
/interface pptp-server server
set enabled=yes
/interface sstp-server server
set default-profile=default-encryption enabled=yes
[admin@MOB] > /firewall export
bad command name firewall (line 1 column 2)
oops, sorry about the firewall.. that was supposed to be:
/ip firewall export
[admin@MOB] >> /ip firewall export
sep/03/2016 16:58:52 by RouterOS 6.36.2
add action=fasttrack-connection chain=forward connection-state=established,related
add action=accept chain=input dst-port=80 protocol=tcp
add action=accept chain=input dst-port=8291 protocol=tcp
add action=accept chain=forward comment=“default configuration” connection-state=
established,related
add action=drop chain=forward comment=“default configuration” connection-state=
invalid
connection-nat-state=!dstnat connection-state=new in-interface=“ATT 1G”
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=accept chain=input comment=“allow l2tp” dst-port=1701 protocol=udp
add action=accept chain=input comment=“allow pptp” dst-port=1723 protocol=tcp
add action=accept chain=input comment=“allow sstp” dst-port=443 protocol=tcp
add action=drop chain=input in-interface=“ATT 1G”
add action=accept chain=input disabled=yes dst-port=8291 protocol=tcp
add action=accept chain=forward connection-state=established,related
add action=masquerade chain=srcnat comment=“default configuration” out-interface=
“ATT 1G”
add action=dst-nat chain=dstnat dst-port=443 in-interface=“ATT 1G” protocol=tcp
to-addresses=192.168.1.5 to-ports=443
add action=dst-nat chain=dstnat dst-port=8921 in-interface=“ATT 1G” protocol=tcp
to-addresses=192.168.1.1 to-ports=8921
add action=dst-nat chain=dstnat comment=DVR dst-port=37777 in-interface=“ATT 1G”
protocol=tcp to-addresses=192.168.1.18 to-ports=37777
protocol=udp to-addresses=192.168.1.18 to-ports=37777
add action=dst-nat chain=dstnat dst-port=5198 in-interface=“ATT 1G” protocol=udp
to-addresses=192.168.1.5 to-ports=5198
add action=dst-nat chain=dstnat dst-port=5199 in-interface=“ATT 1G” protocol=udp
to-addresses=192.168.1.5 to-ports=5199
add action=masquerade chain=srcnat comment=“masq. vpn traffic” src-address=
192.168.89.0/24
/ip firewall service-port
set sip disabled=yes
[admin@MOB] >>
right off, I would say you need to remove the LAN port from the bridge, and delete the bridge. You have a switch chip and no wireless interfaces, so a software bridge isn’t needed.
Ok, I went to bridge and deleted the LAN port and then deleted the bridge completely.
That didn’t seem to help:
http://puu.sh/r6Bzw/2c1ce92c9d.png
what do you get with speedtest.net or fast.com?
I don’t understand why you still test with btest. Is not reliable and will not reflect real world situations.
What are you trying to achieve? Gigabit between lan ports? Make a transfer between computers.
He is a new forum user, and very likely has not read the threads on the btest client/server.
Sorry for the late reply here. I’ve been doing a lot of testing and finally was able to get this fix. Fasttrack was the solution, but I did not realize that the commands had to be run PLUS you have to drag the fasttrack rule to the top of the firewall list. That was my mistake. Thanks to everyone that helped. Here are the results, CPU much lower and the speed much higher!
https://i.imgur.com/868FW4Z.png
looks good, and thanks for the update. Glad you worked it out.
