We have 2 x IPSec tunnels that connect to the same supplier ( Peer details are all the same ), the only difference between the two connections is each tunnel has a different Dst Addresses.
The problem we have is the two connections don’t seem to be able to be active at the same time. If you enable both one will have a PH2 State of “No Phase2” and if you disable the one that works the other one then connects and visa versa
Is there a way to have both tunnels active at the same time, ultimately they have different subnets so i cant understand why its not working. At the moment the only way we can get it working is to disable one tunnel to be able to connect to the one we need manually.
