Unable to install RouterOS x86
Hi guys,
I have been trying to install RouterOS 6.36 in a Dell R710 with Dual CPU. I was able to boot from the CD, but the RouterOS installer isn’t able to find any hard disk drive. I tried configuring the drive in RAID 0, then in RAID 1, then directly connected to the SATA port and in all cases the RouterOS installer didn’t find any HDD. Any idea?
I tried with standard HDD and SSD.
Thanks,
It will not run with RAID. For onboard SATA, you will need to disable AHCI and set the drives as IDE.
A better solution is install VMware ESXi and run the CHR virtual machine.
