Good afternoon! I have a Debian VPS server that I use as a routing server, I configured it with the mikrotik hex s client, there are pings, but I can’t log into mikrotik via winbox
[admin@kgu-aktanberdi] > /export
# 2024-11-06 12:56:57 by RouterOS 7.16.1
/interface wireguard
add listen-port=51820 mtu=1420 name=wireguard1
/interface lte apn
set udp-timeout=10s
/ipv6 settings
/interface ovpn-server server
set auth=sha1,md5
/interface wireguard peers
add allowed-address=192.168.12.0/24 endpoint-address=############ endpoint-port=51820 interface=wireguard1 name=peer1 persistent-keepalive=20s public-key=\
add address=192.168.12.3/24 interface=wireguard1 network=192.168.12.0
/ip dhcp-client
add interface=ether1
add action=accept chain=input dst-port=51820 in-interface=wireguard1 protocol=udp
add action=accept chain=forward in-interface=wireguard1 out-interface=ether1
add action=accept chain=forward in-interface=ether1 out-interface=wireguard1
add action=log chain=input dst-port=51820 in-interface=wireguard1 log-prefix=WireGuard-Input: protocol=udp
add action=log chain=forward in-interface=wireguard1 log-prefix=WireGuard-Forward:
add action=accept chain=input dst-port=8291 in-interface=wireguard1 protocol=tcp
add action=accept chain=input dst-port=8291 in-interface=ether1 protocol=tcp
add action=masquerade chain=srcnat out-interface=wireguard1
/ip hotspot profile
/ip ipsec profile
add disabled=no dst-address=192.168.1.0/24 gateway=192.168.12.1 routing-table=main suppress-hw-offload=no
add dst-address=192.168.12.0/24 gateway=192.168.12.1
/system clock
set time-zone-name=Asia/Almaty
/system identity
set name=kgu-aktanberdi
/system note
set show-at-login=no
