Please help me, I am unable to login with the default password under my mikrotik RB951Ui-2HnD router after resetting the router.
I cannot also login with empty password.
Then reset was not done correctly.
Check, double check, triple check the password, see:
Trouble with Mikrotik passwords? Read here
Try again the reset,
I find taking a photo of the password tag end enlarging it often shows me that my eyes lied to me . . .
@rextended posted a way that will work even if you don't have the correct label.
But it does involve netinstall and a custom script that will set the system id to the default password saved in nvram (rom?) And you should have the device disconnected from other networks because the password will be in the CLI prompt (or even visible from winbox, it will be broadcast with MNDP) until you login and change it.
NOTE WELL. Always try a blank password first before you try this, because attempting to set the the system id to null will not work, and you will have just wasted your time.
Example: This is from an RB760iGS purchased in 2020, before MikroTik started shipping routers with unique "random" passwords, and the "default" password on this router is "" null.
[demo@MikroTik] > /sys id set name=$defconfPassword
failure: empty identity string
[demo@MikroTik] > /sys id set name=test
[demo@test] >
For example capital I, and small L can easily mixed, you should take care about them. Or if you will not be able to log in after multiple tries, you can do netintall
The password Is ONLY UPPER CASE LETTERS.
1 and I (CAPITAL i) confusion is possible, 1 and l (small L) Is not, as this latter Is not part of any Mikrotik default password.
See the already given link;
It was just an example, that some numbers, capital and small letters can be the same in printing.
