Unable to nexthop via LTE interface
normally I would set up recursive via static gateways, but when the device has an LTE gateway, I can’t figure out how to it. Reverting to netwatch and changing the route is basically my only option at this stage. This makes life more difficult than it has to be because instead of deploying 1xLtAP +2xR11eLTE or a WAPLTEAC with a LHGLTE, i now need to either run netwatch and change distance until it comes back or I need to use a HAP with 2 line coming in and use that for failover.
Any ideas? The problem seems to stem from the fact that when using LTE interface/APN, it doesn’t actually load a gateway. The device is the gateway.
