Unable to Ping 5009 VLAN to 5009 to Non-VLAN
I've been playing around (i.e., trying to learn) and I'm stuck.
Two RB5009 units: Unit 1 is named 212-RB5009, unit 2 is 212-RB5009-New
212-RB5009's WAN is ether1, connected to FIOS.
212-RB5009-New (ether6) is connected to 212-RB5009 (ether5).
212-RB5009 is non-VLAN and is also connected to a CRS326 using SPF on both sides.
212-RB5009-New is set up with VLANs (for eventual implementation).
I can't get the 2 RB5009s to talk to each other. I've tried adding specific routes to each other's IP addresses using the local ether port as the gateways.
Here is a diagram. For bigger picture clarification: The RB5009 and the CRS326 are production (in use, operational, necessary -- and I am loath to make any changes to them). Whereas, RB5009-New and hAPax3 are the test lab.
Exports in next messages (size constraint).
RB5009:
# 2025-10-24 07:15:00 by RouterOS 7.19.3
# software id = 2KBD-7ZZB
# model = RB5009UPr+S+
# serial number = HDA0
add admin-mac=18:FD:74:CF:7F:5D auto-mac=no comment=defconf name=bridge \
    port-cost-mode=short
set [ find default-name=ether1 ] comment=WAN poe-out=off
set [ find default-name=ether2 ] comment=hAPax3-Downstairs poe-out=off
set [ find default-name=ether3 ] comment="JRS PC port 3" poe-out=off
set [ find default-name=ether4 ] comment=hAPax3-Upstairs poe-out=off
set [ find default-name=ether5 ] comment=<empty> poe-out=off
set [ find default-name=ether6 ] comment="MOCA adapter" poe-out=off
set [ find default-name=ether7 ] comment=OffBridge poe-out=off
set [ find default-name=ether8 ] comment=BI-Server poe-out=off
set [ find default-name=sfp-sfpplus1 ] comment=CSS326
/interface wireguard
add listen-port=51820 mtu=1420 name=212-Wireguard private-key=\
    "WIPddddd+2L0A="
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=MANAGE
add name=DHCPdisabled
add name=TRUSTED
add name=IoT-Cameras
/iot lora servers
add address=eu.mikrotik.thethings.industries name=TTN-EU protocol=UDP
add address=us.mikrotik.thethings.industries name=TTN-US protocol=UDP
add address=eu1.cloud.thethings.industries name="TTS Cloud (eu1)" protocol=\
    UDP
add address=nam1.cloud.thethings.industries name="TTS Cloud (nam1)" protocol=\
    UDP
add address=au1.cloud.thethings.industries name="TTS Cloud (au1)" protocol=\
    UDP
add address=eu1.cloud.thethings.network name="TTN V3 (eu1)" protocol=UDP
add address=nam1.cloud.thethings.network name="TTN V3 (nam1)" protocol=UDP
add address=au1.cloud.thethings.network name="TTN V3 (au1)" protocol=UDP
/iot mqtt brokers
add address=192.168.0.103 client-id=192.168.2.2 name=HA password=XXXXX \
    username=mqtt
add address=192.168.0.162 auto-connect=yes name="Home Assistant" password=\
    XXXXX username=mqtt
add name=192.168.2.100-200 ranges=192.168.2.100-192.168.2.200
add comment=offbridge-dhcp-server name=offbridge-dhcp-server ranges=\
    192.168.55.101-192.168.55.200
add address-pool=192.168.2.100-200 interface=bridge lease-script="\
    \n/system\
    \n:local cdate [clock get date] \
    \n:local yyyy  [:pick \$cdate 0  4]\
    \n:local MM    [:pick \$cdate 5  7]\
    \n:local dd    [:pick \$cdate 8 10]\
    \n\
    \n:local thistime [/system clock get time]\
    \n:local thishour [:pick \$thistime 0 2]\
    \n:local thisminute [:pick \$thistime 3 5]\
    \n:local thissecond [:pick \$thistime 6 8]\
    \n:local identitydatetime \"\$[identity get name]_\$yyyy-\$MM-\$dd_\$thish\
    our:\$thisminute:\$thissecond\"\
    \n:local datetime \"\$yyyy-\$MM-\$dd_\$thishour:\$thisminute:\$thissecond\
    \n:local systemname \"\$[identity get name]\"\
    \n\
    \n#:if (\$leaseBound=1) do={\
    \n\
    \n#  :log info \"testing after condition BOUND\" }\
    \n\
    \n#:if  ([/ip dhcp-server lease find where dynamic mac-address=\$leaseActM\
    AC]!=\"\") do={\
    \n\
    \n#  :log info \"testing after condition DYNAMIC\"}\
    \n\
    \n\
    \n:if  ((\$leaseBound=1)  && ([/ip dhcp-server lease find where dynamic ma\
    c-address=\$leaseActMAC]!=\"\") && ([/ip dhcp-server lease find where comm\
    ent mac-address=\$leaseActMAC]=\"\")) do={\
    \n\
    \n#    :log info \"testing after conditions BOUND and DYNAMIC and EMPTY CO\
    MMENT\" \
    \n\
    \n:local recipient \"jXXXXX@domain.com\"\
    \n\
    \n #   :tool e-mail send to=\$recipient subject=\"\$systemname DHCP Lease \
    Assigned to \$leaseActMAC\" body=\"MAC address \$leaseActMAC received IP a\
    ddress \$leaseActIP with a hostname of \$[/ip/dhcp-server/lease/get value-\
    name=host-name [find where mac-address=\$leaseActMAC]] from DHCP Server \$\
    leaseServerName on \$datetime from \$systemname with comment \$[/ip/dhcp-s\
    erver/lease/get value-name=comment [find where mac-address=\$leaseActMAC]]\
    \n\
    \n\
    \n#    :log info \"Sent DHCP alert for MAC \$leaseActMAC\"\
    \n\
    \n}\
    \n\
    \n\
    \n\
    \n\
    \n" lease-time=3d name=defconf
add address-pool=offbridge-dhcp-server comment=offbridge-dhcp-server \
    interface=ether7 name=offbridge-dhcp-server
/ip smb users
/system logging action
set 3 remote=192.168.2.22
add name=logserver remote=192.168.0.112 remote-port=51400 target=remote
add email-to=jXXXXX@domain.com name=email target=email
add disk-file-name=UPSLOG name=diskups target=disk
/container config
set registry-url=https://registry-1.docker.io tmpdir=disk1/pull
/interface bridge filter
add action=drop chain=forward disabled=yes dst-port=67-68 in-interface-list=\
    DHCPdisabled ip-protocol=udp log-prefix=Bridge-Filter-Forward \
    mac-protocol=ip out-interface-list=DHCPdisabled src-port=67-68
add action=drop chain=input disabled=yes dst-port=67-68 in-interface-list=\
    DHCPdisabled ip-protocol=udp log-prefix=Bridge-Filter-Input mac-protocol=\
    ip src-port=67-68
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2 \
    internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5 \
add bridge=bridge interface=ether6 internal-path-cost=10 path-cost=10
add bridge=bridge interface=ether8 internal-path-cost=10 path-cost=10
add bridge=bridge interface=sfp-sfpplus1
set udp-timeout=10s
set discover-interface-list=TRUSTED
/ipv6 settings
set accept-redirects=no accept-router-advertisements=no disable-ipv6=yes \
    forward=no max-neighbor-entries=8192 soft-max-neighbor-entries=8191
add disabled=yes interface=bridge list=MANAGE
add disabled=yes interface=ether1 list=MANAGE
add interface=212-Wireguard list=LAN
add disabled=yes interface=212-Wireguard list=MANAGE
add interface=212-Wireguard list=DHCPdisabled
add disabled=yes interface=*13 list=DHCPdisabled
add disabled=yes interface=*14 list=DHCPdisabled
add disabled=yes interface=*12 list=DHCPdisabled
add disabled=yes interface=*17 list=DHCPdisabled
add disabled=yes interface=*18 list=DHCPdisabled
add disabled=yes interface=*15 list=DHCPdisabled
add disabled=yes interface=*16 list=DHCPdisabled
add comment=OffBridge interface=ether7 list=LAN
add disabled=yes interface=ether7 list=MANAGE
add interface=bridge list=TRUSTED
add interface=ether7 list=TRUSTED
add interface=212-Wireguard list=TRUSTED
/interface ovpn-server server
add mac-address=FE:B2:B3:FE:59:72 name=ovpn-server1
/interface wireguard peers
add allowed-address=10.10.100.8/32 comment="JRS Laptop" interface=\
    212-Wireguard name=jrs-laptop public-key=\
    "b9iyIPddddddjRpJX8="
add allowed-address=\
    10.10.100.2/32,192.168.88.0/24,10.10.100.40/32,192.168.40.0/24 comment=\
    371 endpoint-address=XXXXX.dyndns.org endpoint-port=52820 interface=\
    212-Wireguard name=371 persistent-keepalive=40s public-key=\
    "zoZtiesddddddU5lohI="
add allowed-address=10.10.100.9/32 comment="JRS iPhone" interface=\
    212-Wireguard name=jrs-iphone public-key=\
    "PypzufCddddddpy61F8="
add allowed-address=10.10.100.12/32,192.168.20.0/24 comment=629 \
    endpoint-address=XXXXX.dyndns.org endpoint-port=51821 interface=\
    212-Wireguard name=629 persistent-keepalive=40s public-key=\
    "q28DddddddoG4CfXo="
add allowed-address=10.10.100.60/32,192.168.1.0/24 comment=255 \
    endpoint-address=XXXXX.dyndns.org endpoint-port=51835 interface=\
    212-Wireguard name=255 persistent-keepalive=40s public-key=\
    "6E3ddddddPMwbRc="
add allowed-address=10.10.100.30/32,192.168.30.1/24 comment=76 \
    endpoint-address=XXXXX.dyndns.org endpoint-port=51830 interface=\
    212-Wireguard name=76 persistent-keepalive=40s public-key=\
    "EJu69dddddcNgUic="
add allowed-address=10.10.90.0/24 comment="BI PC WG APP" endpoint-port=51820 \
    interface=212-Wireguard name=peer8 public-key=\
    "R5SjZudddddSC0jt9TV4="
add allowed-address=10.10.100.1/32,192.168.2.2/24 comment=\
    "212 (local, just for reference);   192.168.2.2" disabled=yes \
    endpoint-address=XXXXX.dyndns.org endpoint-port=51820 interface=\
    212-Wireguard name=peer9 public-key=\
    "xx2ddddddOqXrW4Ds="
add allowed-address=10.10.100.100/32 comment="JRS Laptop 201" disabled=yes \
    interface=212-Wireguard name=peer10 public-key=\
    "QJCXZdddddddeqsSFk="
add allowed-address=10.10.100.101/32 endpoint-port=51840 interface=\
    212-Wireguard name=peer11 public-key=\
    "N/t6/8dddddGQQZsW8="
add allowed-address=10.10.100.70/32,192.168.70.0/24 comment=125 \
    endpoint-address=XXXXX.dyndns.org endpoint-port=51870 interface=\
    212-Wireguard name=125 persistent-keepalive=40s public-key=\
    "Otp5dddddayGqT8="
add allowed-address=10.10.100.99/32,192.168.2.0/24 comment="JRS Laptop 2023" \
    interface=212-Wireguard name=peer13 private-key=\
    "ED8Ig6ddddddyBZH//vOc9p2Q=" public-key=\
    "w9XFdddddMndCHiU="
add allowed-address=10.10.100.53/32,192.168.0.0/24 client-listen-port=51840 \
    comment="WG Proxmox Win11" endpoint-address=XXXXX.dyndns.org \
    endpoint-port=51844 interface=*12 name=peer15 public-key=\
    "Wut4dddddGRDk="
add allowed-address=10.10.100.15/32 comment=355-AX3 disabled=yes \
    endpoint-address=10.0.0.1 endpoint-port=51860 interface=212-Wireguard \
    name=355-ax3 persistent-keepalive=40s public-key=\
    "C6fhddddd3LZ04="
add allowed-address=10.10.100.10/32 comment="T Laptop" interface=\
    212-Wireguard name=t-laptop public-key=\
    "MbtddddddmL+itsBc="
add allowed-address=10.10.100.80/32,192.168.80.1/24,10.72.0.0/16 comment=729 \
    endpoint-address=xxxx.dyndns.org endpoint-port=51880 interface=\
    212-Wireguard name=729 persistent-keepalive=40s public-key=\
    "dddddd0CQ="
add allowed-address=10.10.100.81/32 comment=hex-lab endpoint-address=\
    192.168.2.192 endpoint-port=51881 interface=212-Wireguard name=peer19 \
    "U/TxIdbddddddj4/y0="
add allowed-address=10.10.100.50/32,192.168.0.0/24,192.168.5.0/24 comment=355 \
    endpoint-address=XXXXX.dyndns.org endpoint-port=51833 interface=\
    212-Wireguard name=355 persistent-keepalive=40s public-key=\
    "Q8CPdddddLZq3g="
add address=192.168.2.2/24 comment=defconf interface=bridge network=\
    192.168.2.0
add address=10.10.100.1/24 interface=212-Wireguard network=10.10.100.0
add address=192.168.55.1/24 interface=ether7 network=192.168.55.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=1h
/ip dhcp-client
add comment=defconf interface=ether1 use-peer-dns=no
/ip dhcp-server alert
add alert-timeout=12h disabled=no interface=bridge on-alert="/system script ad\
    d name=rogue-dhcp source=\94:log warning message=\\\94Rogue DHCP server de\
    tected!\\\94\94"
add alert-timeout=30m interface=bridge on-alert=rogue-dhcp
add address=192.168.2.0/24 comment=defconf dns-server=192.168.2.2 gateway=\
    192.168.2.2 netmask=24
add address=192.168.55.0/24 dns-server=1.1.1.1 gateway=192.168.55.1 netmask=\
    24
set allow-remote-requests=yes cache-max-ttl=3d cache-size=10000KiB servers=\
    9.9.9.9,1.1.1.1,8.8.4.4
/ip dns static
add address=192.168.2.8 name=212-rb5009.212.local type=A
add address=192.168.2.2 name=RB5009.212.local ttl=9w6d10h40m type=A
add address=10.10.100.1 name=212.10.10.100.1.local ttl=9w6d10h40m type=A
add address=192.168.2.100 comment="automatic-from-comment (magic comment)" \
    name=TV15.212.local ttl=1h type=A
add address=192.168.2.121 comment="automatic-from-comment (magic comment)" \
    name="Ipad SRN.212.local" ttl=9w6d10h40m type=A
add address=192.168.2.138 comment="automatic-from-comment (magic comment)" \
    name=MFCL3770CDW.212.local ttl=9w6d10h40m type=A
add address=192.168.2.141 comment="automatic-from-comment (magic comment)" \
    name="JRS iPhone.212.local" ttl=9w6d10h40m type=A
add address=192.168.2.109 comment="automatic-from-comment (magic comment)" \
    name="Vizio on 15.212.local" ttl=9w6d10h40m type=A
add address=192.168.2.122 comment="automatic-from-comment (magic comment)" \
    name=Homepod.212.local ttl=9w6d10h40m type=A
add address=192.168.2.199 comment="automatic-from-comment (magic comment)" \
    name=Playstation.212.local ttl=9w6d10h40m type=A
add address=192.168.2.142 comment="automatic-from-comment (magic comment)" \
    name=SRNAppleWatch.212.local ttl=9w6d10h40m type=A
add address=192.168.2.22 name=JRS-PC.212.local type=A
add address=192.168.2.102 comment="automatic-from-dhcp (magic comment)" name=\
    Master-Bedroom.212.local ttl=1h40m type=A
add address=192.168.2.103 comment="automatic-from-dhcp (magic comment)" name=\
    Family-Room.212.local ttl=1h40m type=A
add address=192.168.2.138 comment="automatic-from-dhcp (magic comment)" name=\
    MFC-L3770.212.local ttl=1h40m type=A
add address=192.168.2.147 comment="automatic-from-dhcp (magic comment)" name=\
    212LR.212.local ttl=1h40m type=A
add address=192.168.2.191 comment="automatic-from-dhcp (magic comment)" name=\
    SRNOffice.212.local ttl=1h40m type=A
add address=192.168.2.128 comment="automatic-from-dhcp (magic comment)" name=\
    212MBR.212.local ttl=1h40m type=A
add address=192.168.2.200 comment="automatic-from-dhcp (magic comment)" name=\
    HarmonyHub.212.local ttl=1h40m type=A
add address=192.168.2.124 comment="automatic-from-dhcp (magic comment)" name=\
    BRW2C6FC95FBCEB.212.local ttl=1h40m type=A
add address=192.168.2.173 comment="automatic-from-dhcp (magic comment)" name=\
    NC-LT-SN20.212.local ttl=1h40m type=A
add address=192.168.2.137 comment="automatic-from-dhcp (magic comment)" name=\
    tasmota-E37677-5751.212.local ttl=1h40m type=A
add address=192.168.2.117 comment="automatic-from-dhcp (magic comment)" name=\
    BRNB4220095598A.212.local ttl=1h40m type=A
add address=192.168.2.127 comment="automatic-from-dhcp (magic comment)" name=\
    Debian.212.local ttl=1h40m type=A
add address=192.168.2.110 comment="automatic-from-dhcp (magic comment)" name=\
    JRS-Laptop-2023.212.local ttl=1h40m type=A
add address=192.168.2.108 comment="automatic-from-dhcp (magic comment)" name=\
    0005CD193C07.212.local ttl=1h40m type=A
add address=69.202.199.148 name=XXXXX.dyndns.org type=A
add address=192.168.2.2 comment=router.212.internal name=router.212.internal \
    type=A
add address=10.10.100.80 comment=729router.internal name=729router.internal \
    type=A
add address=192.168.2.22 comment=jrspc name=jrspc.212.internal type=A
/ip firewall address-list
add address=XXXXX.dyndns.org list=dynamic-WANIP
add address=192.168.0.0/16 list=Authorized
add address=10.10.100.0/24 list=Authorized
add address=XXXXX.dyndns.org list=XXXXX
add address=hda08a4mazh.sn.mynetname.net list=PublicIP
add action=log chain=input comment="Port 53 Log" connection-state=new \
    disabled=yes dst-port=53 log=yes log-prefix=TCP-53 protocol=tcp
    established,related,untracked
    invalid
add action=accept chain=input comment="Loopback allow" dst-address=127.0.0.1
add action=accept chain=input comment="Allow incoming WG connections" \
    dst-port=51820 protocol=udp
add action=drop chain=input comment="DROP DHCP on DHCPdisabled" disabled=yes \
    dst-port=67-68 in-interface-list=DHCPdisabled log=yes protocol=udp \
    src-port=67-68
add action=accept chain=input comment="Allow GRE for EoIP" disabled=yes log=\
    yes protocol=gre
add action=accept chain=input comment="Allow Authorized" src-address-list=\
    Authorized
add action=accept chain=input comment="Allow LAN" in-interface-list=LAN
add action=drop chain=input comment="drop all else" log-prefix=drop-all-else
add action=drop chain=forward comment="defconf:  drop invalid" \
    connection-state=invalid
add action=accept chain=forward comment="Allow WG to subnet" dst-address=\
    192.168.2.0/24 in-interface=212-Wireguard
add action=accept chain=forward comment="Allow all traffic out WG iface" \
    out-interface=212-Wireguard
add action=accept chain=forward comment="Allows cross peer subnet traffic" \
    in-interface=212-Wireguard out-interface=212-Wireguard
add action=accept chain=forward comment="Allow LAN to WAN" disabled=yes \
    in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="allow port forwarding" \
    connection-nat-state=dstnat disabled=yes
/ip firewall mangle
add action=mark-connection chain=prerouting comment=\
    "Mark connection for hairpin" disabled=yes dst-address-list=dynamic-WANIP \
    log=yes new-connection-mark="Hairpin NAT" src-address=192.168.2.0/24
add action=masquerade chain=srcnat comment="Hairpin NAT" connection-mark=\
    "Hairpin NAT" dst-address=192.168.2.0/24 src-address=192.168.2.0/24
add action=dst-nat chain=dstnat comment=XXXXX.dyndns.org:81 \
    dst-address-list=XXXXX dst-port=81 log-prefix=\
    "NAT FW destination XXXXX port 81" protocol=tcp to-addresses=\
    192.168.0.101 to-ports=81
add action=dst-nat chain=dstnat comment=XXXXX.dyndns.org:8123 \
    dst-address-list=XXXXX dst-port=8123 protocol=tcp to-addresses=\
    192.168.0.162 to-ports=8123
add action=masquerade chain=srcnat comment="NEW defconf: masquerade" \
add action=dst-nat chain=dstnat dst-address-list=dynamic-WANIP dst-port=8123 \
    protocol=tcp to-addresses=192.168.2.176
    "Hairpin NAT" disabled=yes dst-address=192.168.2.0/24 src-address=\
    192.168.2.0/24
    disabled=yes out-interface-list=WAN
add action=dst-nat chain=dstnat disabled=yes dst-address-list=dynamic-WANIP \
    dst-port=8123 protocol=tcp to-addresses=192.168.2.176
    dst-port=5911 log=yes protocol=tcp to-addresses=192.168.2.139
add action=dst-nat chain=dstnat disabled=yes dst-port=51833 protocol=udp \
    to-addresses=192.168.2.50
    192.168.2.0/24
/ip ipsec profile
/ip kid-control
add fri=0s-1d mon=0s-1d name=Monitor sat=0s-1d sun=0s-1d thu=0s-1d tue=0s-1d \
    wed=0s-1d
add disabled=yes distance=1 dst-address=192.168.5.0/24 gateway=212-Wireguard \
    pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
    target-scope=10
add disabled=yes distance=1 dst-address=0.0.0.0/0 gateway=192.168.2.2 \
    target-scope=10
add comment=355 disabled=no distance=1 dst-address=192.168.0.0/24 gateway=\
    212-Wireguard pref-src="" routing-table=main scope=30 \
    suppress-hw-offload=no target-scope=10
add comment=255 disabled=no distance=1 dst-address=192.168.1.0/24 gateway=\
add comment=355-Cameras disabled=no distance=1 dst-address=192.168.5.0/24 \
    gateway=212-Wireguard pref-src="" routing-table=main scope=30 \
add comment=629 disabled=no distance=1 dst-address=192.168.20.0/24 gateway=\
add disabled=no distance=1 dst-address=192.168.60.0/24 gateway=192.168.2.8 \
    target-scope=10
add comment=76 disabled=no distance=1 dst-address=192.168.30.0/24 gateway=\
add comment=371 disabled=no distance=1 dst-address=192.168.40.0/24 gateway=\
add comment=125 disabled=no distance=1 dst-address=192.168.70.0/24 gateway=\
add disabled=yes distance=1 dst-address=10.0.0.0/24 gateway=192.168.2.5 \
    target-scope=10
add comment="TEMP -- REMOVE THIS WHEN 729 AX3 is moved" disabled=yes \
    distance=1 dst-address=172.16.0.0/16 gateway=192.168.2.192 routing-table=\
    main scope=30 suppress-hw-offload=no target-scope=10
add disabled=no distance=1 dst-address=10.0.0.0/8 gateway=212-Wireguard \
    routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add disabled=yes distance=1 dst-address=192.168.4.0/24 gateway=10.10.100.80 \
add comment=729 disabled=no distance=1 dst-address=192.168.80.0/24 gateway=\
    212-Wireguard routing-table=main scope=30 suppress-hw-offload=no \
    target-scope=10
add disabled=yes distance=1 dst-address=10.21.0.0/16 gateway=ether5 \
/ip service
set ftp disabled=yes
set telnet disabled=yes
set www disabled=yes
set www-ssl disabled=no
set api disabled=yes
/ip smb shares
set [ find default=yes ] directory=/pub
/ip ssh
set always-allow-password-login=yes forwarding-enabled=both
/snmp
set enabled=yes trap-version=2
/system clock
set time-zone-name=America/New_York
/system identity
set name=212-RB5009
/system logging
set 0 topics=info,!wireguard,!dhcp
add topics=account
add topics=watchdog
add action=logserver prefix="XXXXXH MikroTik" topics=hotspot
add action=logserver prefix="XXXXXH MikroTik" topics=\
    !debug,!packet,!snmp
add action=remote disabled=yes prefix=192.168.2.2 topics=info
add action=remote disabled=yes topics=ups
add topics=ups
add disabled=yes topics=dns
add topics=firewall
add action=diskups regex="^\\[UPS\\]:" topics=script
add action=disk topics=watchdog
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp server
set enabled=yes
/system ntp client servers
add address=216.239.35.4
add address=104.16.132.229
/system ups
add name=ups1 port=usbhid1
/system watchdog
set auto-send-supout=yes ping-start-after-boot=10m ping-timeout=10m \
    send-email-to=jXXXXX@domain.com watch-address=1.1.1.1
/tool bandwidth-server
set authenticate=no
/tool e-mail
set from=jXXXXX@domain.com password="<dddd>" port=587 \
    server=smtp.gmail.com tls=starttls user=<dddd>@gmail.com
/tool graphing interface
add
/tool graphing queue
add
/tool graphing resource
add
add
/tool mac-server
/tool mac-server mac-winbox
set allowed-interface-list=TRUSTED
/tool romon
set enabled=yes
/tool sniffer
set file-limit=10000KiB filter-ip-address=10.21.0.0/16 filter-ip-protocol=\
    icmp memory-limit=10000KiB streaming-server=192.168.2.22
/tool traffic-monitor
add disabled=yes interface=ether1 name=tmon1
add disabled=yes interface=ether3 name=tmon2 traffic=received trigger=always
RB5009-New:
# 2025-10-24 07:14:59 by RouterOS 7.18.2
# model = RB5009UG+S+
add admin-mac=F4:1E:57:C3:6E:8A ageing-time=5m arp=enabled arp-timeout=auto \
    auto-mac=no comment=defconf dhcp-snooping=no disabled=no ether-type=\
    0x8100 fast-forward=yes forward-delay=15s frame-types=\
    admit-only-vlan-tagged igmp-snooping=no ingress-filtering=yes \
    max-learned-entries=auto max-message-age=20s mtu=auto mvrp=no name=bridge \
    port-cost-mode=short priority=0x8000 protocol-mode=rstp pvid=1 \
    transmit-hold-count=6 vlan-filtering=yes
set [ find default-name=ether1 ] advertise="10M-baseT-half,10M-baseT-full,100M\
    -baseT-half,100M-baseT-full,1G-baseT-half,1G-baseT-full,2.5G-baseT" arp=\
    enabled arp-timeout=auto auto-negotiation=yes bandwidth=\
    unlimited/unlimited comment=WAN disabled=no l2mtu=1514 loop-protect=\
    default loop-protect-disable-time=5m loop-protect-send-interval=5s \
    mac-address=F4:1E:57:C3:6E:89 mtu=1500 name=ether1 orig-mac-address=\
    F4:1E:57:C3:6E:89 rx-flow-control=off tx-flow-control=off
set [ find default-name=ether2 ] advertise="10M-baseT-half,10M-baseT-full,100M\
    -baseT-half,100M-baseT-full,1G-baseT-half,1G-baseT-full" arp=enabled \
    arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited \
    comment="Switch JRS Office; vlan32 access" disabled=no l2mtu=1514 \
    loop-protect=default loop-protect-disable-time=5m \
    loop-protect-send-interval=5s mac-address=F4:1E:57:C3:6E:8A mtu=1500 \
    name=ether2 orig-mac-address=F4:1E:57:C3:6E:8A rx-flow-control=off \
    tx-flow-control=off
set [ find default-name=ether3 ] advertise="10M-baseT-half,10M-baseT-full,100M\
    comment="Blue Iris Server vlan62 access port" disabled=no l2mtu=1514 \
    loop-protect-send-interval=5s mac-address=F4:1E:57:C3:6E:8B mtu=1500 \
    name=ether3 orig-mac-address=F4:1E:57:C3:6E:8B rx-flow-control=off \
    tx-flow-control=off
set [ find default-name=ether4 ] advertise="10M-baseT-half,10M-baseT-full,100M\
    comment="hAPax3-downstairs trunk vlans 2, 12, 32, 42" disabled=no l2mtu=\
    1514 loop-protect=default loop-protect-disable-time=5m \
    loop-protect-send-interval=5s mac-address=F4:1E:57:C3:6E:8C mtu=1500 \
    name=ether4 orig-mac-address=F4:1E:57:C3:6E:8C rx-flow-control=off \
    tx-flow-control=off
set [ find default-name=ether5 ] advertise="10M-baseT-half,10M-baseT-full,100M\
    comment="hAPax3-upstairs trunk vlans 2, 12, 32, 42" disabled=no l2mtu=\
    loop-protect-send-interval=5s mac-address=F4:1E:57:C3:6E:8D mtu=1500 \
    name=ether5 orig-mac-address=F4:1E:57:C3:6E:8D rx-flow-control=off \
    tx-flow-control=off
set [ find default-name=ether6 ] advertise="10M-baseT-half,10M-baseT-full,100M\
    comment="Joseph PC access port vlan32" disabled=no l2mtu=1514 \
    loop-protect-send-interval=5s mac-address=F4:1E:57:C3:6E:8E mtu=1500 \
    name=ether6 orig-mac-address=F4:1E:57:C3:6E:8E rx-flow-control=off \
    tx-flow-control=off
set [ find default-name=ether7 ] advertise="10M-baseT-half,10M-baseT-full,100M\
    comment="MGMT access port vlan32" disabled=no l2mtu=1514 loop-protect=\
    mac-address=F4:1E:57:C3:6E:8F mtu=1500 name=ether7 orig-mac-address=\
    F4:1E:57:C3:6E:8F rx-flow-control=off tx-flow-control=off
set [ find default-name=ether8 ] advertise="10M-baseT-half,10M-baseT-full,100M\
    comment=OffBridge disabled=no l2mtu=1514 loop-protect=default \
    loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=\
    F4:1E:57:C3:6E:90 mtu=1500 name=ether8 orig-mac-address=F4:1E:57:C3:6E:90 \
set [ find default-name=sfp-sfpplus1 ] advertise="10M-baseT-half,10M-baseT-ful\
    l,100M-baseT-half,100M-baseT-full,1G-baseT-half,1G-baseT-full,1G-baseX,2.5\
    G-baseT,2.5G-baseX,5G-baseT,10G-baseT,10G-baseSR-LR,10G-baseCR" arp=\
    unlimited/unlimited comment=CSS326 disabled=no l2mtu=1514 loop-protect=\
    mac-address=F4:1E:57:C3:6E:91 mtu=1500 name=sfp-sfpplus1 \
    orig-mac-address=F4:1E:57:C3:6E:91 rx-flow-control=off sfp-ignore-rx-los=\
    no sfp-rate-select=high sfp-shutdown-temperature=95C tx-flow-control=off
/queue interface
set bridge queue=no-queue
set wireguard1 queue=no-queue
/interface vlan
add arp=enabled arp-timeout=auto comment="TV VLAN42" disabled=no interface=\
    bridge loop-protect=default loop-protect-disable-time=5m \
    loop-protect-send-interval=5s mtu=1500 mvrp=no name=vlan-TV \
    use-service-tag=no vlan-id=42
add arp=enabled arp-timeout=auto comment="Cameras VLAN22" disabled=no \
    interface=bridge loop-protect=default loop-protect-disable-time=5m \
    loop-protect-send-interval=5s mtu=1500 mvrp=no name=vlan-camera \
    use-service-tag=no vlan-id=22
add arp=enabled arp-timeout=auto comment="Guest WiFi VLAN2" disabled=no \
    loop-protect-send-interval=5s mtu=1500 mvrp=no name=vlan-guest \
add arp=enabled arp-timeout=auto comment="IoT  VLAN12" disabled=no interface=\
    loop-protect-send-interval=5s mtu=1500 mvrp=no name=vlan-iot \
    use-service-tag=no vlan-id=12
add arp=enabled arp-timeout=auto comment="MGMT VLAN32" disabled=no interface=\
    loop-protect-send-interval=5s mtu=1500 mvrp=no name=vlan-mgmt \
    use-service-tag=no vlan-id=32
add arp=enabled arp-timeout=auto comment="MOCA VLAN52" disabled=no interface=\
    loop-protect-send-interval=5s mtu=1500 mvrp=no name=vlan-moca \
    use-service-tag=no vlan-id=52
add arp=enabled arp-timeout=auto comment="Printers vlan82" disabled=no \
    loop-protect-send-interval=5s mtu=1500 mvrp=no name=vlan-printers \
    use-service-tag=no vlan-id=82
add arp=enabled arp-timeout=auto comment="Servers VLAN62" disabled=no \
    loop-protect-send-interval=5s mtu=1500 mvrp=no name=vlan-server \
    use-service-tag=no vlan-id=62
add arp=enabled arp-timeout=auto comment="VONAGE VLAN72" disabled=no \
    loop-protect-send-interval=5s mtu=1500 mvrp=no name=vlan-vonage \
    use-service-tag=no vlan-id=72
/interface ethernet switch
set 0 cpu-flow-control=yes mirror-egress-target=none name=switch1
set 0 !egress-rate !ingress-rate mirror-egress=no mirror-ingress=no \
    mirror-ingress-target=none
set 1 !egress-rate !ingress-rate mirror-egress=no mirror-ingress=no \
set 2 !egress-rate !ingress-rate mirror-egress=no mirror-ingress=no \
set 3 !egress-rate !ingress-rate mirror-egress=no mirror-ingress=no \
set 4 !egress-rate !ingress-rate mirror-egress=no mirror-ingress=no \
set 5 !egress-rate !ingress-rate mirror-egress=no mirror-ingress=no \
set 6 !egress-rate !ingress-rate mirror-egress=no mirror-ingress=no \
set 7 !egress-rate !ingress-rate mirror-egress=no mirror-ingress=no \
set 8 !egress-rate !ingress-rate mirror-egress=no mirror-ingress=no \
set 9 !egress-rate !ingress-rate mirror-egress=no mirror-ingress=no \
/interface ethernet switch port-isolation
set 0 !forwarding-override
set 1 !forwarding-override
set 2 !forwarding-override
set 3 !forwarding-override
set 4 !forwarding-override
set 5 !forwarding-override
set 6 !forwarding-override
set 7 !forwarding-override
set 8 !forwarding-override
set 9 !forwarding-override
set [ find name=all ] comment="contains all interfaces" exclude="" include="" \
    name=all
set [ find name=none ] comment="contains no interfaces" exclude="" include="" \
    name=none
set [ find name=dynamic ] comment="contains dynamic interfaces" exclude="" \
    include="" name=dynamic
set [ find name=static ] comment="contains static interfaces" exclude="" \
    include="" name=static
add comment=defconf exclude="" include="" name=WAN
add comment=defconf exclude="" include="" name=LAN
add exclude="" include="" name=TRUSTED
add exclude="" include="" name=Iot-Cameras
/interface lte apn
set [ find default=yes ] add-default-route=yes apn=internet authentication=\
    none default-route-distance=2 ip-type=auto name=default use-network-apn=\
    yes use-peer-dns=yes
/interface macsec profile
set [ find default-name=default ] name=default server-priority=10
/ip dhcp-client option
set clientid_duid code=61 name=clientid_duid value="0xff\$(CLIENT_DUID)"
set clientid code=61 name=clientid value="0x01\$(CLIENT_MAC)"
set hostname code=12 name=hostname value="\$(HOSTNAME)"
/ip hotspot profile
set [ find default=yes ] dns-name="" hotspot-address=0.0.0.0 html-directory=\
    hotspot html-directory-override="" http-cookie-lifetime=3d http-proxy=\
    0.0.0.0:0 install-hotspot-queue=no login-by=cookie,http-chap name=default \
    smtp-server=0.0.0.0 split-user-domain=no use-radius=no
    192.168.55.2-192.168.55.200
add name=guest-pool ranges=10.21.2.100-10.21.2.252
add name=iot-pool ranges=10.21.12.100-10.21.12.252
add name=cameras-pool ranges=10.21.22.100-10.21.22.252
add name=mgmt-pool ranges=10.21.32.100-10.21.32.252
add name=TV-pool ranges=10.21.42.100-10.21.42.252
add name=MOCA-pool ranges=10.21.52.100-10.21.52.252
add name=servers-pool ranges=10.21.62.100-10.21.62.252
add name=vonage-pool ranges=10.21.72.100-10.21.72.252
add address-lists="" address-pool=guest-pool disabled=no interface=vlan-guest \
    lease-script="" lease-time=30m name=dhcp-guest use-radius=no
add address-lists="" address-pool=iot-pool disabled=no interface=vlan-iot \
    lease-script="" lease-time=30m name=dhcp-iot use-radius=no
add address-lists="" address-pool=mgmt-pool disabled=yes interface=vlan-mgmt \
    lease-script="" lease-time=30m name=dhcp-mgmt use-radius=no
# Interface not running
add address-lists="" address-pool=offbridge-dhcp-server comment=\
    offbridge-dhcp-server disabled=no interface=ether8 lease-script="" \
    lease-time=30m name=offbridge-dhcp-server use-radius=no
add address-lists="" address-pool=MOCA-pool disabled=no interface=vlan-moca \
    lease-script="" lease-time=30m name=dhcp-moca use-radius=no
add address-lists="" address-pool=servers-pool disabled=no interface=\
    vlan-server lease-script="" lease-time=30m name=dhcp-servers use-radius=\
    no
add address-lists="" address-pool=TV-pool disabled=no interface=vlan-TV \
    lease-script="" lease-time=30m name=dhcp-TV use-radius=no
add address-lists="" address-pool=vonage-pool disabled=no interface=\
    vlan-vonage lease-script="" lease-time=30m name=dhcp-vonage use-radius=no
/queue type
set 0 kind=pfifo name=default pfifo-limit=50
set 1 kind=pfifo name=ethernet-default pfifo-limit=50
set 2 kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set 3 kind=red name=synchronous-default red-avg-packet=1000 red-burst=20 \
    red-limit=60 red-max-threshold=50 red-min-threshold=10
set 4 kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set 5 kind=pcq name=pcq-upload-default pcq-burst-rate=0 pcq-burst-threshold=0 \
    pcq-burst-time=10s pcq-classifier=src-address pcq-dst-address-mask=32 \
    pcq-dst-address6-mask=128 pcq-limit=50KiB pcq-rate=0 \
    pcq-src-address-mask=32 pcq-src-address6-mask=128 pcq-total-limit=2000KiB
set 6 kind=pcq name=pcq-download-default pcq-burst-rate=0 \
    pcq-burst-threshold=0 pcq-burst-time=10s pcq-classifier=dst-address \
    pcq-dst-address-mask=32 pcq-dst-address6-mask=128 pcq-limit=50KiB \
    pcq-rate=0 pcq-src-address-mask=32 pcq-src-address6-mask=128 \
set 7 kind=none name=only-hardware-queue
set 8 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set 9 kind=pfifo name=default-small pfifo-limit=10
add auto-isolate=no bpdu-guard=no bridge=bridge broadcast-flood=yes comment=\
    "hAPax3-upstairs trunk vlan1" disabled=no edge=auto fast-leave=no \
    frame-types=admit-only-vlan-tagged horizon=none hw=yes ingress-filtering=\
    yes interface=ether5 !internal-path-cost learn=auto multicast-router=\
    temporary-query mvrp-applicant-state=normal-participant \
    mvrp-registrar-state=normal !path-cost point-to-point=auto priority=0x80 \
    pvid=1 restricted-role=no restricted-tcn=no tag-stacking=no trusted=no \
    unknown-multicast-flood=yes unknown-unicast-flood=yes
    "JRS PC; assign vlan32; access port" disabled=no edge=auto fast-leave=no \
    frame-types=admit-only-untagged-and-priority-tagged horizon=none hw=yes \
    ingress-filtering=yes interface=ether6 !internal-path-cost learn=auto \
    multicast-router=temporary-query mvrp-applicant-state=normal-participant \
    pvid=32 restricted-role=no restricted-tcn=no tag-stacking=no trusted=no \
    "MGMT; assign vlan32; access port " disabled=no edge=auto fast-leave=no \
    ingress-filtering=yes interface=ether7 !internal-path-cost learn=auto \
    "CSS326; trunk vlan1" disabled=no edge=auto fast-leave=no frame-types=\
    admit-only-vlan-tagged horizon=none hw=yes ingress-filtering=yes \
    interface=sfp-sfpplus1 !internal-path-cost learn=auto multicast-router=\
    "JRS office switch; vlan32; access port" disabled=no edge=auto \
    fast-leave=no frame-types=admit-only-untagged-and-priority-tagged \
    horizon=none hw=yes ingress-filtering=yes interface=ether2 \
    internal-path-cost=10 learn=auto multicast-router=temporary-query \
    mvrp-applicant-state=normal-participant mvrp-registrar-state=normal \
    path-cost=10 point-to-point=auto priority=0x80 pvid=32 restricted-role=no \
    restricted-tcn=no tag-stacking=no trusted=no unknown-multicast-flood=yes \
    "Blue Iris; assign vlan62 tag; access port" disabled=no edge=auto \
    horizon=none hw=yes ingress-filtering=yes interface=ether3 \
    path-cost=10 point-to-point=auto priority=0x80 pvid=62 restricted-role=no \
    "hAPax3-downstairs; trunk vlan1" disabled=no edge=auto fast-leave=no \
    yes interface=ether4 internal-path-cost=10 learn=auto multicast-router=\
    mvrp-registrar-state=normal path-cost=10 point-to-point=auto priority=\
    0x80 pvid=1 restricted-role=no restricted-tcn=no tag-stacking=no trusted=\
    no unknown-multicast-flood=yes unknown-unicast-flood=yes
/interface bridge settings
set allow-fast-path=yes use-ip-firewall=no use-ip-firewall-for-pppoe=no \
    use-ip-firewall-for-vlan=no
set enabled=auto generic-timeout=10m icmp-timeout=10s loose-tcp-tracking=yes \
    tcp-close-timeout=10s tcp-close-wait-timeout=10s tcp-established-timeout=\
    1d tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
    tcp-max-retrans-timeout=5m tcp-syn-received-timeout=5s \
    tcp-syn-sent-timeout=5s tcp-time-wait-timeout=10s tcp-unacked-timeout=5m \
    udp-stream-timeout=3m udp-timeout=30s
set discover-interface-list=all discover-interval=30s lldp-mac-phy-config=no \
    lldp-max-frame-size=no lldp-med-net-policy-vlan=disabled lldp-vlan-info=\
    no mode=tx-and-rx protocol=cdp,lldp,mndp
/interface bridge vlan
add bridge=bridge comment=\
    "ports bridge,4,5,sfp to carry vlan2 (Guest) tagged frames out of 5009" \
    disabled=no mvrp-forbidden="" tagged=bridge,ether4,ether5,sfp-sfpplus1 \
    untagged="" vlan-ids=2
    "port bridge,4,5,sfp to carry vlan12 (IoT) tagged frames out of 5009" \
    untagged="" vlan-ids=12
add bridge=bridge comment="ports bridge,4,5,sfp to carry vlan32 (MGMT) out of \
    5009 AND assign vlan32 to frames arriving on ports 6,7; access 32 for ethe\
    r2, 6, 7" disabled=no mvrp-forbidden="" tagged=\
    bridge,sfp-sfpplus1,ether4,ether5 untagged=ether2,ether6,ether7 vlan-ids=\
    32
    "ports bridge,4,5,sfp to carry vlan42 (TV) frames out of 5009" disabled=\
    no mvrp-forbidden="" tagged=bridge,ether4,ether5,sfp-sfpplus1 untagged="" \
    vlan-ids=42
    "ports bridge,sfp to carry vlan52(MOCA)  out of 5009" disabled=no \
    mvrp-forbidden="" tagged=bridge,sfp-sfpplus1 untagged="" vlan-ids=52
add bridge=bridge comment="ports bridge,sfp to carry vlan62 (server) frames ou\
    t of 5009 AND assign vlan62 to frames arriving at ether3" disabled=no \
    mvrp-forbidden="" tagged=bridge,sfp-sfpplus1 untagged=ether3 vlan-ids=62
    "ports bridge,sfp to carry vlan72 (vonage) frames out of 5009" disabled=\
    no mvrp-forbidden="" tagged=bridge,sfp-sfpplus1 untagged="" vlan-ids=72
    "ports bridge,sfp to carry vlan 82 (printer) frames out of 5009" \
    disabled=no mvrp-forbidden="" tagged=bridge,sfp-sfpplus1 untagged="" \
    vlan-ids=82
add comment=defconf disabled=no interface=ether1 list=WAN
add disabled=no interface=wireguard1 list=TRUSTED
add disabled=no interface=ether8 list=TRUSTED
add disabled=no interface=wireguard1 list=LAN
add comment="LAN OffBridge" disabled=no interface=ether5 list=LAN
add comment="TRUSTED OffBridge" disabled=no interface=ether5 list=TRUSTED
add comment="LAN VLAN2" disabled=no interface=vlan-guest list=LAN
add comment="LAN VLAN12" disabled=no interface=vlan-iot list=LAN
add comment="LAN VLAN32" disabled=no interface=vlan-mgmt list=LAN
add comment="TRUSTED VLAN32" disabled=no interface=vlan-mgmt list=TRUSTED
add disabled=no interface=vlan-iot list=Iot-Cameras
add comment="TEMP " disabled=no interface=ether1 list=TRUSTED
add comment="LAN VLAN62" disabled=no interface=vlan-server list=LAN
add comment="LAN VLAN52" disabled=no interface=vlan-moca list=LAN
add comment="LAN VLAN42" disabled=no interface=vlan-TV list=LAN
add disabled=no interface=ether8 list=LAN
add address=192.168.55.1/24 disabled=no interface=ether8 network=192.168.55.0
add address=10.10.100.212/24 disabled=no interface=wireguard1 network=\
    10.10.100.0
add address=10.21.2.1/24 disabled=no interface=vlan-guest network=10.21.2.0
add address=10.21.12.1/24 disabled=no interface=vlan-iot network=10.21.12.0
add address=10.21.32.1/24 disabled=no interface=vlan-mgmt network=10.21.32.0
add address=10.21.42.1/24 disabled=no interface=vlan-TV network=10.21.42.0
add address=10.21.52.1/24 disabled=no interface=vlan-moca network=10.21.52.0
add address=10.21.62.1/24 disabled=no interface=vlan-server network=\
    10.21.62.0
add address=10.21.72.1/24 disabled=no interface=vlan-vonage network=\
    10.21.72.0
add address=10.21.82.1/24 disabled=no interface=vlan-printers network=\
    10.21.82.0
/ip dhcp-client
add add-default-route=yes comment=defconf default-route-distance=1 \
    default-route-tables=default dhcp-options=hostname,clientid disabled=no \
    interface=ether1 use-peer-dns=yes use-peer-ntp=yes
/ip dhcp-server config
set accounting=yes interim-update=0s radius-password=empty store-leases-disk=\
    5m
add address=10.21.2.0/24 caps-manager="" dhcp-option="" dns-server=10.21.2.1 \
    gateway=10.21.2.1 !next-server ntp-server="" wins-server=""
add address=10.21.12.0/24 caps-manager="" dhcp-option="" dns-server=\
    10.21.12.1 gateway=10.21.12.1 !next-server ntp-server="" wins-server=""
add address=10.21.22.0/24 caps-manager="" dhcp-option="" dns-server=\
    10.21.22.1 gateway=10.21.22.1 !next-server ntp-server="" wins-server=""
add address=10.21.32.0/24 caps-manager="" dhcp-option="" dns-server=1.1.1.1 \
    gateway=10.21.32.1 !next-server ntp-server="" wins-server=""
add address=10.21.42.0/24 caps-manager="" dhcp-option="" dns-server=\
    10.21.42.1 gateway=10.21.42.1 !next-server ntp-server="" wins-server=""
add address=10.21.52.0/24 caps-manager="" dhcp-option="" dns-server=\
    10.21.52.1 gateway=10.21.52.1 !next-server ntp-server="" wins-server=""
add address=10.21.62.0/24 caps-manager="" dhcp-option="" dns-server=\
    10.21.62.1 gateway=10.21.62.1 !next-server ntp-server="" wins-server=""
add address=10.21.72.0/24 caps-manager="" dhcp-option="" dns-server=\
    10.21.72.1 gateway=10.21.72.1 !next-server ntp-server="" wins-server=""
add address=192.168.55.0/24 caps-manager="" dhcp-option="" dns-server=1.1.1.1 \
    gateway=192.168.55.1 netmask=24 !next-server ntp-server="" wins-server=""
set address-list-extra-time=0s allow-remote-requests=yes cache-max-ttl=1w \
    cache-size=10000KiB doh-max-concurrent-queries=50 \
    doh-max-server-connections=5 doh-timeout=5s max-concurrent-queries=100 \
    max-concurrent-tcp-sessions=20 max-udp-packet-size=4096 \
    mdns-repeat-ifaces="" query-server-timeout=2s query-total-timeout=10s \
    servers=1.1.1.1,9.9.9.9 use-doh-server="" verify-doh-cert=no vrf=main
/ip dns static
add address=10.21.32.1 disabled=no name=212-rb5009-new.212.internal ttl=1d \
    type=A
add address=10.21.32.1 disabled=no name=RB5009-new.212.internal ttl=\
    9w6d10h40m type=A
add address=10.21.32.1 disabled=no name=212.10.10.100.212.internal ttl=\
    9w6d10h40m type=A
add address=10.21.32.22 disabled=no name=vlan-JRSPC.212.internal ttl=1d type=\
    A
add address=192.168.2.2 comment=router.212.internal disabled=no name=\
    router.212.internal ttl=1d type=A
add address=10.21.32.1 comment=router.212.internal disabled=no name=\
    vlan-router.212.internal ttl=1d type=A
add address=10.10.100.80 comment=729router.internal disabled=no name=\
    729router.internal ttl=1d type=A
add address=192.168.2.22 disabled=no name=jrspc.212.internal ttl=1d type=A
add address=XXXXX.dyndns.org disabled=no dynamic=no list=dynamic-WANIP
add address=192.168.0.103 comment="Home Assistant" disabled=no dynamic=no \
    list=ALLOWED-REMOTE-SERVERS
add address=192.168.55.0/24 disabled=no dynamic=no list=admin
add address=10.0.0.0/8 disabled=no dynamic=no list=admin
add address=192.168.2.168 comment="Blue Iris 2" disabled=no dynamic=no list=\
add address=192.168.0.101 comment="Blue Iris" disabled=no dynamic=no list=\
    invalid
add action=accept chain=input comment="Allow INPUT users to services" \
    dst-port=53 in-interface-list=LAN log-prefix=users-to-services protocol=\
    udp
    dst-port=53 in-interface-list=LAN protocol=tcp
add action=accept chain=input comment="Allow INPUT from TRUSTED" \
    in-interface-list=TRUSTED
add action=accept chain=input comment="Allow INPUT WG Handshake" dst-port=\
    51880 log-prefix=Allow-WG-Handshake protocol=udp
add action=accept chain=input comment="NTP to Devices" !connection-bytes \
    !connection-limit !connection-mark !connection-nat-state !connection-rate \
    !connection-state !connection-type !content disabled=no !dscp \
    !dst-address !dst-address-list !dst-address-type !dst-limit !dst-port \
    !fragment !hotspot !icmp-options !in-bridge-port !in-bridge-port-list \
    in-interface=vlan-mgmt !in-interface-list !ingress-priority !ipsec-policy \
    !ipv4-options !layer7-protocol !limit log=no log-prefix="" !nth \
    !out-bridge-port !out-bridge-port-list !out-interface !out-interface-list \
    !packet-mark !packet-size !per-connection-classifier !port !priority \
    protocol=udp !psd !random !routing-mark !src-address !src-address-list \
    !src-address-type !src-mac-address src-port=123 !tcp-flags !tcp-mss !time \
    !tls-host !ttl
add action=drop chain=input comment="Drop all INPUT" !connection-bytes \
    !in-interface !in-interface-list !ingress-priority !ipsec-policy \
    !ipv4-options !layer7-protocol !limit log=no log-prefix=DROP-ALL !nth \
    !protocol !psd !random !routing-mark !src-address !src-address-list \
    !src-address-type !src-mac-address !src-port !tcp-flags !tcp-mss !time \
    !tls-host !ttl
add action=fasttrack-connection chain=forward comment=\
    "defconf: fasttrack established related" connection-state=\
    established,related hw-offload=yes
add action=accept chain=forward comment="Allow FORWARD LAN to WAN" \
    in-interface-list=LAN log-prefix=Allow-LAN-WAN out-interface-list=WAN
add action=accept chain=forward comment="Allow FORWARD TRUSTED" \
    in-interface-list=TRUSTED log-prefix=Allow-TRUSTED out-interface-list=LAN
    "Allow FORWARD Admin & remote wg admin to wireguard" in-interface-list=\
    TRUSTED out-interface=wireguard1 src-address-list=admin
    "Allow FORWARD IOT-CAMERAS iface to ALLOWED-REMOTE-SERVER" \
    dst-address-list=ALLOWED-REMOTE-SERVERS in-interface-list=Iot-Cameras \
add action=accept chain=forward comment="Allow WG relay" in-interface=\
    wireguard1 out-interface=wireguard1
add action=drop chain=forward comment="Drop all FORWARD" log-prefix=DROP-ALL
    ipsec-policy=out,none out-interface-list=WAN !to-addresses !to-ports
add action=masquerade chain=srcnat out-interface=wireguard1 !to-addresses \
    !to-ports
    wireguard1 pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
    target-scope=10
    target-scope=10
    gateway=wireguard1 pref-src="" routing-table=main scope=30 \
    target-scope=10
    target-scope=10
    target-scope=10
    target-scope=10
add disabled=no distance=1 dst-address=192.168.4.0/24 gateway=10.10.100.80 \
add disabled=no distance=1 dst-address=10.0.0.0/8 gateway=wireguard1 \
/system identity
set name=212-RB5009-New
/tool mac-server
/tool mac-server ping
set enabled=yes
/tool romon
set enabled=yes id=00:00:00:00:00:00
/tool romon port
set [ find default=yes ] cost=100 disabled=no forbid=no interface=all
Set your /interface bridge bridge's pvid to 32.
I think that made it work!
Do I understand correctly that by setting the RB5009’s bridge’s pvid to 32 the bridge allows all the traffic in from the RB5009-New?
(That setting is done on RB5009-New I think?) Yes, now RB5009-New’s bridge port has access to your manage VLAN 32, so it can communicate with RB5009.
I was testing the ping connectivity from the wrong device.
I changed the pvid on RB5009-New to 32 and tried it with “admit all” as well as “admit only VLAN” and still cannot ping from the RB5009-New to RB5009
Could you show us the result of /interface/bridge/vlan/printon both RB5009?
VLANs exist only on RB5009-New:
[admin@212-RB5009-New] > /interface/bridge/vlan/print
Flags: D - DYNAMIC
Columns: BRIDGE, VLAN-IDS, CURRENT-TAGGED, CURRENT-UNTAGGED
#   BRIDGE  VLAN-IDS  CURRENT-TAGGED  CURRENT-UNTAGGED
;;; ports bridge,4,5,sfp to carry vlan2 (Guest) tagged frames out of 5009
0   bridge         2  bridge
                      sfp-sfpplus1
                      ether4
;;; port bridge,4,5,sfp to carry vlan12 (IoT) tagged frames out of 5009
1   bridge        12  bridge
                      sfp-sfpplus1
                      ether4
;;; ports bridge,4,5,sfp to carry vlan32 (MGMT) out of 5009 AND assign vlan32 to frames arriving on ports 6,7; access 32 for ether2, 6, 7
2   bridge        32  bridge          ether6
                      sfp-sfpplus1
                      ether4
;;; ports bridge,4,5,sfp to carry vlan42 (TV) frames out of 5009
3   bridge        42  bridge
                      sfp-sfpplus1
                      ether4
;;; ports bridge,sfp to carry vlan52(MOCA)  out of 5009
4   bridge        52  bridge
                      sfp-sfpplus1
;;; ports bridge,sfp to carry vlan62 (server) frames out of 5009 AND assign vlan62 to frames arriving at ether3
5   bridge        62  bridge
                      sfp-sfpplus1
;;; ports bridge,sfp to carry vlan72 (vonage) frames out of 5009
6   bridge        72  bridge
                      sfp-sfpplus1
7   bridge        82  bridge
                      sfp-sfpplus1
;;; added by vlan on bridge
8 D bridge        22  bridge
With this result, you haven’t set bridge’s pvid to 32 yet, since it’s not automatically added to untagged ports of vlan 32.
Remove bridgefrom tagged port list of vlan 32.
Why is this static route disabled?
I really don’t want to just keep trying things because then I will end up with a completely non-functioning config.
Is there something specific in either or both of the configs that prevents traffic flow?
When I ping from RB5009-New 192.168.2.2 (the IP address of RB5009), packet sniffer does not show the packets and the ping message is: “no route to host”
I tried adding a direct route to 192.168.2.0/24 as well as 192.168.2.2/32 via ether4 as well as via Bridge and the message changes to: “22 (Invalid argument)”
I even tried disabling vlan filtering in the bridge and that did not help.
I figured it out:
The multiple cables connecting RB5009-New (VLAN-aware router) resulted in multiple paths and the devices got “confused.”
After removing the source of confusion (disabling SFP2 interface) , I was able to add 192.168.2.33/24 to ether6 and it works.
Since ether6 is a member of the bridge,
you should not be applying an ip address to it. It should be applied to the bridge itself. Adding the ip address to a bridge-port is like putting a license plate on a passenger in the car, instead of on the car.
You may want to consider adding a dhcp-client to the bridge on RB5009-New, and setting a reserved ip address for the bridge's mac address to the dhcp server on RB5009 (aka RB5009-1) for 192.168.1.0/24. Then RB5009-New (aka RB5009vlan-1) will automatically get a default gateway via the RB5009-1 bridge.
Also, in the future when you are posting configs, leave off the "verbose"; using export verbose makes finding the significant information much harder. The config for the RB5009 (RB5009-1) was fine, it was the RB5009-New (RB5009vlan-1) that was hard to read.
