Unable to ping from the DUDE in CentOS Please Help!
I’m new to centOS but not so new to the dude. The problem is that I can use every other service (http,ssl, etc.) to monitor from the dude. But, I really need ping to work, for some reason it gives the error- local problem. I tested it from the terminal and it pings fine. I’m using WINE to run dude and it is running as a service. Please Help! Thank you!
You likely need to start wine/dude with root permissions.
Thank you for your reply! But, I’m a newbie in centOS and have searched for a way to run Wine/Dude with root permissions but couldn’t find anything…could you please point me in the right direction?
I’m not sure how you are starting it but from CLI “sudo wine /path/to/dude.exe” maybe. There is a guide in the forum that you should be able to find with search.
