I have tried to reset the router using the small “RES” button behind the case. It didn’t seem to work. According to the wiki, there should be a dhcp server on ETH2,3,4,5 and the router’s IP should be 192.168.88.1.
Unfortunately none of those look to be functioning.
I can’t get any IP form the router and even with a fixed IP on the computer, I’m unable too connect.
Do you have any ideas?
Johan.
Use mac for connection.
Just like Jarda said, try using Winbox app and instead of the IP, use the MAC address to connect. You can automatically detect the right MAC address using the […] button in Winbox.
