Unable to reset router
Hello
I have a bit of a problem for whatever reason the last two times I have reset my RB2011UiAS-2HnD-IN has borked. The first time it would get stuck on the loading kernel screen and I managed to fix it with the Netinstall tool. This is the second time this happened but now the router will boot, will not provide a default gateway address, and the reset button has stopped working since this has happened so I can not use the Netinstall tool. Would anyone have a solution to my problem? I can reset it with the LCD but this method does not seem to do anything.
Looks like you may have a hardware problem?
Did you check LOG?
Sadly I cant even find a way to get a log. Is their another way in to the device besides win box and an Ethernet port 2? Or another way to reset the device? Before it did this I was trying to open a port then broken.
