Hello folks,
i was encountering a very strange (to me..) behaviour on my RB450G (latest 6.36rc40 firmware).
WAN port connected to a 192.168.1.0/24 network (where is the VDSL modem)
over the WAN port i make a pppoE connection
LAN1,2,3,4 (master-slave-slave-slave) and is on 10.10.10.0/24 network
if i try, from LAN1(2/3/4) to ping/http to a client over the 192.168.1.0 network it will not answer.
the only way i have to make them communicate is to masquerade the traffic out of the WAN port.
I still think that is not right… because, it is a router ? doesn’t it ?
this is the printout of my interfaces, ip/address and ip/routes
[admin@MikroTik] /interface> print
# NAME TYPE ACTUAL-MTU L2MTU MAX-L2MTU
0 R lan1 ether 1500 1520 1520
1 S lan2 ether 1500 1520 1520
2 S lan3 ether 1500 1520 1520
3 RS lan4 ether 1500 1520 1520
4 R wan ether 1500 1520 1520
5 R ;;; TIM Fibra 100
Fibra100 pppoe-out 1480
[admin@MikroTik] /ip route> print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 Fibra100 1
1 ADC 10.10.10.0/24 10.10.10.1 lan1 0
2 ADC 192.168.1.0/24 192.168.1.2 wan 0
3 ADC 192.168.100.1/32 79.44.191.227 Fibra100 0
and right now is working with that ip/nat rule
[admin@MikroTik] /ip firewall nat> print
0 ;;; masq traffic from WAN interface
chain=srcnat action=masquerade dst-address=192.168.1.0/24 out-interface=wan log=no log-prefix=""
can you explain my why ?
