I have a set up in which 10 stations are connected to AP.
I upgraded the stations to 6.44.2 while that of the AP is still at 6.43.8.
The issue is that I cannot do a bandwidth test from the station to the client while the test can run from the AP to the client.
Anyone with any explanation will be highly appreciated.
Also, if a solution can be provided…Thank you.
For as far as I know, since firmware version ??? the two devices you want to run a test on must have the same firmware version.
