I have a problem where I am unable to see my NAS as a network device when connected to my network via WiFi. I’ve setup my new RB962.
Here’s my setup…
Synology NAS configured with a static ip (192.168.10.3) connected to the LAN
Multiple computers connected to LAN using DHCP (address range 192.168.10.100-192.168.10.199)
Multiple WiFi devices connected to the WLAN using DHCP (address range 192.168.20.100-192.168.20.199)
From a WiFi connection I am able to connect the NAS via the UI (http://192.168.10.3:5000) and I can ping IP addresses on the LAN from WLAN devices and the other way around, so as far as I can tell the bridges are able to “talk”.
If I change my config and put all interfaces on a single bridge and use the same subnet for both LAN and WLAN things seems to works fine, but I’d like to keep the LAN and WLAN on separate subnets if possible.
I suspect it’s probably some minor configuration that I’ve missed, but what do I know ![]()
I’ve include parts of my configuration below.
Configuration:
add name=bridge-lan
add name=bridge-wlan
/ip neighbor discovery
set bridge-lan
set bridge-wlan
add address=192.168.10.1/24 \
comment="LAN" \
interface=bridge-lan \
network=192.168.10.0
add address=192.168.20.1/24 \
comment="WLAN" \
interface=bridge-wlan \
network=192.168.20.0
add name=dhcp-lan \
ranges=192.168.10.100-192.168.10.199
add name=dhcp-wlan \
ranges=192.168.20.100-192.168.20.199
add address-pool=dhcp-lan \
disabled=no \
lease-time=6d \
name=dhcp-server-lan
add address-pool=dhcp-wlan \
disabled=no \
lease-time=3d \
name=dhcp-server-wlan
add address=192.168.10.0/24 \
comment="LAN DHCP Server" \
dns-server=192.168.10.1 \
gateway=192.168.10.1 \
netmask=24
add address=192.168.20.0/24 \
comment="WLAN DHCP Server" \
dns-server=192.168.20.1 \
gateway=192.168.20.1 \
netmask=24
add bridge=bridge-lan \
comment="LAN" \
interface=ether2-lan-master
add bridge=bridge-wlan \
comment="WLAN1" \
interface=wlan1
comment="WLAN2" \
interface=wlan2
