I am trying to send logs to a remote listening application on port 514…
I have configured action and topics to be sent, but I am not getting any connections to my application that I have built using VB.NET…
Below the configuration on my Mikrotik:
[admin@MikroTik] /system logging> export
# jan/10/2015 17:59:02 by RouterOS 6.24
# software id = JZHP-NVRD
/system logging action
set 0 memory-lines=100
set 1 disk-lines-per-file=100
set 3 bsd-syslog=yes remote=192.168.1.10 remote-port=23 src-address=0.0.0.0 \
syslog-facility=local0
/system logging
add action=remote topics=!async
add action=echo topics=!async
add action=remote topics=system,info
Also here is the code I use on my VB.NET project:
Imports System
Imports System.IO
Imports System.Net
Imports System.Net.Sockets
Imports System.Text
Module Module1
Sub Main()
Dim server As TcpListener
server = Nothing
Try
' Set the TcpListener on port 13000.
Dim port As Int32 = 23
'Dim localAddr As IPAddress = IPAddress.Parse("192.168.1.10")
'server = New TcpListener(localAddr, port)
Dim localAddr As IPAddress()
localAddr = Dns.GetHostAddresses(Dns.GetHostName.ToString)
Console.WriteLine("Listening on IP: " & localAddr(5).ToString)
server = New TcpListener(localAddr(5), port)
' Start listening for client requests.
server.Start()
' Buffer for reading data
Dim bytes(1024) As Byte
Dim data As String = Nothing
' Enter the listening loop.
While True
Console.WriteLine("Waiting for a connection... ")
' Perform a blocking call to accept requests.
' You could also user server.AcceptSocket() here.
Dim client As TcpClient = server.AcceptTcpClient()
Console.WriteLine("Connected!")
data = Nothing
' Get a stream object for reading and writing
Dim stream As NetworkStream = client.GetStream()
Dim i As Int32
' Loop to receive all the data sent by the client.
i = stream.Read(bytes, 0, bytes.Length)
While (i <> 0)
' Translate data bytes to a ASCII string.
data = System.Text.Encoding.ASCII.GetString(bytes, 0, i)
Console.WriteLine("Received: {0}", data)
' Process the data sent by the client.
'data = data.ToUpper()
'Dim msg As Byte() = System.Text.Encoding.ASCII.GetBytes(data)
' Send back a response.
'stream.Write(msg, 0, msg.Length)
'Console.WriteLine("Sent: {0}", data)
End While
' Shutdown and end connection
client.Close()
End While
Catch e As SocketException
Console.WriteLine("SocketException: {0}", e)
Finally
server.Stop()
End Try
Console.WriteLine(ControlChars.Cr + "Hit enter to continue....")
Console.Read()
End Sub
End Module
I appreciate any help or guidance on this!
Regards
