unable to send mail using gmail (auth failed)?
does someone know if Google\Gmail change something ?
I just notice I can’t send E-mail in the last 2 months
I get
Error sending e-mail <test>: AUTH failed
and in the gmail it said "Critical security error "
what do I need to change and where ?
** the password is correct
/tool e-mail
set address=smtp.gmail.com from=Myroutertest12@gmail.com password=******** port=587 start-tls=yes user=Myroutertest12
Thanks ,
Have you enabled sending of email through less secure applications on your gmail account ?
https://myaccount.google.com/lesssecureapps
Be careful, this does NOT work if your Gmail account has 2-factor enabled.
I use a separate gmail account for this sending of mails 1) to keep it out of my primary account, 2) my primary account has 2-factor enabled.
You can still use the 2-Step-Verification if you create a specific gmail app password. https://support.google.com/accounts/answer/185833?hl=en
Right ! Missed that one … still keeping the accounts separate, though :slight_smile:
this is just a router gmail account for sending data
I didn’t know I can make a
You can still use the 2-Step-Verification if you create a specific gmail app password. > https://support.google.com/accounts/answer/185833?hl=en
i will try it
Thanks ,
No, it’s not possible to auth to google using user and password. They removed this option and “Less secure access” was forcefully turned OFF by google last month on regular accounts.
Another reason not to have email handled by google…
You can use app passwords.
