Hi, I can no longer SSH into my Mikrotik using it’s public IP. This was working fine and then without any change it is not.
I can still get in on private IP but when I try using the public IP, I get an error message. I have tried this on Bash for Windows, a Fedora machine and Putty.
The error message I get from Bash for Windows is:
ssh: connect to host port 22: Resource temporarily unavailable
On Putty I get “Network error, timed out”.
Here are some of my settings, can somebody please help? Thank you.
ip rou pri
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADS 0.0.0.0/0 2.127.238.108 1
1 ADC 2.127.238.108/32 pppoe-out1 0
2 DC 10.0.0.0/24 10.0.0.1 HomeNetwork 255
3 DC 10.0.20.0/24 10.0.20.1 management 255
4 DC 10.0.30.0/24 10.0.30.1 Internet 255
5 ADC 192.168.88.0/24 192.168.88.1 LAN 0
/ip firewall nat> print
0 ;;; default configuration
chain=srcnat action=masquerade out-interface=SkyDsl
1 chain=srcnat action=masquerade src-address=192.168.88.0/24
2 chain=dstnat action=dst-nat to-addresses=192.168.88.241 to-ports=48085 protocol=tcp dst-address=
dst-port=48085
3 chain=dstnat action=dst-nat to-addresses=192.168.88.241 to-ports=48085 protocol=udp dst-address=
dst-port=48085
4 ;;; FIFA17_1
chain=dstnat action=dst-nat to-addresses=192.168.88.241 to-ports=9000-9999 protocol=tcp
dst-address=
5 chain=srcnat action=masquerade to-addresses=10.0.0.0/24 out-interface=SkyDsl
6 chain=srcnat action=masquerade to-addresses=10.0.30.0/24 out-interface=SkyDsl
> ip ser pri
NAME PORT ADDRESS CERTIFICATE
0 telnet 23
1 ftp 21
2 www 80
3 ssh 22
4 X www-ssl 443 none
5 api 8728
6 winbox 8291
7 api-ssl 8729 none
/ip firewall> filter print
chain=input action=accept protocol=icmp
1 ;;; default configuration
chain=input action=accept connection-state=established
2 ;;; default configuration
chain=input action=accept connection-state=related
3 ;;; default configuration
chain=forward action=accept connection-state=established
4 ;;; default configuration
chain=forward action=accept connection-state=related
5 ;;; Accept established connections
6 ;;; Accept related connections
7 ;;; Allow limited pings
chain=input action=accept protocol=icmp limit=50/5s,2
8 ;;; From our LAN
chain=input action=accept src-address=192.168.88.0/24 in-interface=LAN
9 ;;; Log everything else
chain=input action=log log-prefix=“DROP INPUT”
10 chain=output action=accept protocol=tcp content=530 Login incorrect dst-limit=1/1m,9,dst-address/1m
11 chain=output action=add-dst-to-address-list protocol=tcp address-list=ftp_blacklist address-list-timeout=3h
12 ;;; Drop Brute Forcers
chain=input action=drop protocol=tcp src-address-list=ssh_blacklist dst-port=22
13 chain=input action=add-src-to-address-list connection-state=new protocol=tcp src-address-list=ssh_stage3
address-list=ssh_blacklist address-list-timeout=1w3d dst-port=22
14 chain=input action=add-src-to-address-list connection-state=new protocol=tcp src-address-list=ssh_stage2
address-list=ssh_stage3 address-list-timeout=1m dst-port=22
15 chain=input action=add-src-to-address-list connection-state=new protocol=tcp src-address-list=ssh_stage1
address-list=ssh_stage2 address-list-timeout=1m dst-port=22
16 ;;; SSH create blacklist
chain=input action=add-src-to-address-list connection-state=new protocol=tcp address-list=ssh_stage1
17 ;;; SSH
chain=input action=accept connection-state=new protocol=tcp dst-port=22
18 chain=forward action=accept
19 chain=forward action=accept protocol=udp dst-port=48085
20 chain=forward action=accept protocol=tcp dst-port=48085
21 ;;; default configuration
chain=forward action=drop connection-state=invalid
22 ;;; Drop invalid connections
chain=input action=drop connection-state=invalid
23 ;;; Drop excess pings
chain=input action=drop protocol=icmp
24 ;;; Drop everything else
25 ;;; drop ftp brute forcers
chain=input action=drop protocol=tcp src-address-list=ftp_blacklist dst-port=21
26 ;;; drop ssh brute forcers
27 ;;; default configuration
chain=input action=drop in-interface=SkyDsl
