Unable to strip netmask from Ip address in script
Hi!
I’m using RB5009 and ROS 7.1rc6
Works fine in terminal but won’t work in a script. Can someone help me or is it a bug?
Alt1
:for i from=( [:len $ipaddress] - 1) to=0 do={
	:if ( [:pick $ipaddress $i] = "/") do={
		:put [:pick $ipaddress 0 $i]
Alt 2
:put [:pick $ipaddress 0 [:find $ipaddress "/"]]
I had to change it to:
:global ipaddress 10.1.101.1/24;
:set ipaddress [:pick $ipaddress 0 [:find $ipaddress "/"]]
to make it work
The solution was to use Global as it was in the Wiki: https://wiki.mikrotik.com/wiki/Manual:Scripting-examples#Strip_netmask
No, that didn’t work for me, I tried the wiki example.
This line is being ignored:
The solution was to set the variable again
Is like you do not know scripting,
“:put” simply write on terminal some text,
if you must “put” the result inside a variable, is obvious than you must use set.
And also on CORRECT way (the $ before ipaddress after set command):
:set $ipaddress [:pick $ipaddress 0 [:find $ipaddress "/"]]
Thank you for pointing me in the right direction!
I’m new to this, and old, but still learning!
The forum is here for that,
have a nice day.
Can you help me, what am I doing wrong here?
/tool netwatch set [find comment=“isp4”] src-address=(([/ip dhcp-client get [find interface=“ether1” %ipaddress [:pick $ipaddress 0 [find $ipaddress “/”
I want to get the ip address only from the dhcp client but I can’t do it
thank you very much
