Unable to Upgrade RB951G
I am trying to upgrade a RB951G.
I followed the Manual upgrade process, using Winbox as per this wiki link.
I successfully uploaded the 6.44.2 via drag-and-drop, and rebooted the router.
Yet the router stayed in 6.33.3
I then tried via Winbox – Packages – Check for Updates
Latest version 6.44.2 came up, and I clicked Download&Install.
The router downloaded the package, and then rebooted two times.
Yet when it comes up, it is still 6.33.3.
When I go into the router’s terminal and try /system package print, I get a listing and they are all in 6.33.3
I then tried in the terminal /log print without-paging and these are the results:
[admin@CLIENT_NAME] > /log print without-paging
12:19:32 interface,info ether1-gateway link up (speed 100M, full duplex)
12:19:32 interface,info ether2-master-local link up (speed 100M, full duplex)
12:19:32 interface,info ether5-slave-local link up (speed 100M, full duplex)
12:19:32 dhcp,info dhcp-client on ether1-gateway got IP address 192.123.123.123
12:19:32 system,info item added
12:19:49 system,info,account user admin logged in from ab:ab:ab:ab:ab:ab via winbox
12:19:50 system,info,account user admin logged in via local
12:25:48 system,info router rebooted
12:26:02 system,info,account user admin logged out via local
12:26:03 system,info,account user admin logged in via local
12:26:05 system,info,account user admin logged out via local
12:26:11 system,info,account user admin logged out via local
12:26:16 system,info,account user admin logged in via local
12:26:20 system,info,account user admin logged out via local
12:27:21 system,info,account user admin logged in via local
Any idea what could be going on?
Thank you
Try Netinstall.
absolutely you should use netinstall :slight_smile:
Thank you both.
I am going back on-site to the client, and doing it then.
I will do a Netinstall dry-run in my lab… as I am running Linux, and will run Netinstall via Wine.
https://wiki.mikrotik.com/wiki/Manual:Netinstall
so good :slight_smile:
