i am starting to use a wAP LR8, I am unable to upgrade to 7.12.1, i use 6.49.17, when i perform the upgrade router reboots but the versioni is still 6.49.17.
Any Idea ?
Thank you.
Mauro
Any Idea ?
Thank you.
Mauro
After upgrade-induced reboot, log usually has something about upgrade process outcome … if it fails, log tells the reason (insufficient storage space is one of reasons, various problems with optional packages are showstoppers ad well).
Thank you,
i get
can not install lora-7.12.1: iot-7.12.1 is not installed, but is required
now i will investigate,
thank you.
Mauro
First, you have to remove lora package from 6.x and the install RouterOS 7.12.1 and then you add iot-7.12.1.
F.
