Unable to use android phone as 3G on RB750Gr3
Is the RB750Gr3 (Hex) supposed to support USB tethering?
Specifically I’m trying to use an Android Phone (ZTE L111) as an internet connection and the Hex doesn’t detect it. I’ve tried plugging the exact same phone into an RB951G-2HnD and it works perfectly.
I couldn’t see any USB options that would help (I see that you have to put the USB ports into host mode on some devices, but that doesn’t seem to apply to the Hex).
My guess is that this relates to the different chip type (mmips) used on the Hex and there aren’t kernel headers / USB drivers to allow me to use the phone. It would be great to know if any USB tethering is possible with the Hex currently. Has anyone had success?
Thanks heaps.
David
