Unable to Winbox-access RB450G, connected to RB493G
Unable to Winbox-access RB450G which is connected to switch ‘2’ of RB493G.
By design, RB493G has 2 switches. Switch 1 consists of ports 10, 15 to 18. Switch 2 has ports 11 to 14. And I’d prefer to leave the two switches as is with the idea of leaving slow coaches (lower than gigabit connection) on swt 2.
On swt 1, I have WAN on port 10 and VLANs on 15-18.
On swt 2, I have 2 VoIP devices (Siemens C470IP and STA 3102) connected to 12 and 13 under a VLAN. On port 14, I have RB450G connected.
My 2 VoIP devices work fine and I can access them via their IP addresses. But I can not access the RB450G via Winbox!
Did I miss something? I’d appreciate some help, pls.
Help, please.
Here is an extract of setting under RB493G.
[quote]/interface bridge
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes \
    disabled=no forward-delay=15s l2mtu=1520 max-message-age=20s mtu=1500 \
    name=bridge_VoIP priority=0x8000 protocol-mode=stp transmit-hold-count=6
    disabled=yes forward-delay=15s max-message-age=20s mtu=1500 name=bridge_other \
set 0 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=\
    WAN disabled=no full-duplex=yes l2mtu=1520 mac-address=XX:XX:XX:XX:XX:XD \
    master-port=none mtu=1500 name=ether10 speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
    disabled=no full-duplex=yes l2mtu=1520 mac-address=XX:XX:XX:XX:XX:XE \
    master-port=none mtu=1500 name=ether11 speed=1Gbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
    disabled=no full-duplex=yes l2mtu=1520 mac-address=XX:XX:XX:XX:XX:XF \
    master-port=none mtu=1500 name=ether12 speed=100Mbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
    disabled=no full-duplex=yes l2mtu=1520 mac-address=XX:XX:XX:XX:XX:X0 \
    master-port=none mtu=1500 name=ether13 speed=10Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
    disabled=no full-duplex=yes l2mtu=1520 mac-address=XX:XX:XX:XX:XX:X1 \
    master-port=none mtu=1500 name=ether14 speed=1Gbps
set 5 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=\
    "To 1810G" disabled=no full-duplex=yes l2mtu=1520 mac-address=\
    XX:XX:XX:XX:XX:X2 master-port=none mtu=1500 name=ether15 speed=1Gbps
set 6 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
    disabled=no full-duplex=yes l2mtu=1520 mac-address=XX:XX:XX:XX:XX:X3 \
    master-port=none mtu=1500 name=ether16 speed=1Gbps
set 7 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
    disabled=no full-duplex=yes l2mtu=1520 mac-address=XX:XX:XX:XX:XX:X4 \
    master-port=none mtu=1500 name=ether17 speed=1Gbps
set 8 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
    disabled=no full-duplex=yes l2mtu=1520 mac-address=XX:XX:XX:XX:XX:X5 \
    master-port=none mtu=1500 name=ether18 speed=1Gbps
/interface vlan
add arp=enabled disabled=no interface=bridge_VoIP l2mtu=1516 mtu=1500 name=\
    VL-104 use-service-tag=no vlan-id=104
add arp=enabled disabled=no interface=bridge_other mtu=1500 name=VL-107 \
    use-service-tag=no vlan-id=107
add arp=enabled disabled=no interface=ether11 l2mtu=1516 mtu=1500 name=VL-200 \
    use-service-tag=no vlan-id=200
/interface bonding
add arp=enabled arp-interval=100ms disabled=no down-delay=10ms lacp-rate=\
    30secs link-monitoring=mii-type1 mii-interval=30ms mode=802.3ad mtu=1500 \
    name=bonding1 primary=none slaves=ether15,ether16,ether17,ether18 \
    transmit-hash-policy=layer-2-and-3 up-delay=0ms
/interface vlan
add arp=enabled disabled=no interface=bonding1 mtu=1500 name=VL-101 \
    use-service-tag=no vlan-id=101
add arp=enabled disabled=no interface=bonding1 mtu=1500 name=VL-102 \
    use-service-tag=no vlan-id=102
add arp=enabled disabled=no interface=bonding1 mtu=1500 name=VL-103 \
    use-service-tag=no vlan-id=103
add arp=enabled disabled=no interface=bonding1 mtu=1500 name=VL-105 \
    use-service-tag=no vlan-id=105
add arp=enabled disabled=no interface=bonding1 mtu=1500 name=Default \
/interface ethernet switch
set switch1 mirror-source=none mirror-target=none name=switch1
set switch2 mirror-source=none mirror-target=none name=switch2
/interface vlan
add arp=enabled disabled=no interface=wlan1 l2mtu=2286 mtu=1500 name=VL-106 \
    use-service-tag=no vlan-id=106
add name=dhcp_pool3 ranges=192.168.106.2-192.168.106.30
add name=dhcp_pool2 ranges=192.168.103.2-192.168.103.30
add name=dhcp_pool1 ranges=192.168.102.2-192.168.102.30
add address-pool=dhcp_pool3 address-pool6="" authoritative=after-2sec-delay \
    bootp-support=static disabled=no interface=wlan1 lease-time=4w2d name=\
    dhcp3
add address-pool=dhcp_pool2 address-pool6="" authoritative=after-2sec-delay \
    bootp-support=static disabled=no interface=bonding1 lease-time=4w2d name=\
    dhcp2
/port
set 0 baud-rate=auto data-bits=8 flow-control=none name=serial0 parity=none \
    stop-bits=1
/system routerboard settings
set baud-rate=115200 boot-delay=2s boot-device=nand-if-fail-then-ethernet \
    boot-protocol=bootp cpu-frequency=680MHz enable-jumper-reset=yes \
    enter-setup-on=any-key force-backup-booter=no silent-boot=no
add bridge=bridge_VoIP disabled=no edge=auto external-fdb=auto horizon=none \
    interface=ether12 path-cost=10 point-to-point=auto priority=0x80
    interface=ether13 path-cost=10 point-to-point=auto priority=0x80
add bridge=bridge_other disabled=no edge=auto external-fdb=auto horizon=none \
    interface=ether14 path-cost=10 point-to-point=auto priority=0x80
    interface=ether10 path-cost=10 point-to-point=auto priority=0x80
set ether10 vlan-header=leave-as-is vlan-mode=fallback
set ether11 vlan-header=leave-as-is vlan-mode=fallback
set ether12 vlan-header=leave-as-is vlan-mode=fallback
set ether13 vlan-header=leave-as-is vlan-mode=fallback
set ether14 vlan-header=leave-as-is vlan-mode=fallback
set ether15 vlan-header=leave-as-is vlan-mode=fallback
set ether16 vlan-header=leave-as-is vlan-mode=fallback
set ether17 vlan-header=leave-as-is vlan-mode=fallback
set ether18 vlan-header=leave-as-is vlan-mode=fallback
set switch1_cpu vlan-header=leave-as-is vlan-mode=fallback
set switch2_cpu vlan-header=leave-as-is vlan-mode=fallback
add disabled=yes ports=ether15 switch=switch1 vlan-id=101
add disabled=yes ports=ether15 switch=switch1 vlan-id=102
add disabled=yes ports=ether15 switch=switch1 vlan-id=103
add disabled=yes ports=ether15 switch=switch1 vlan-id=104
add disabled=yes ports=ether15 switch=switch1 vlan-id=105
add disabled=yes ports=ether15 switch=switch1 vlan-id=106
add disabled=yes ports=ether10 switch=switch1 vlan-id=1
add disabled=no ports=ether12,ether13 switch=switch2 vlan-id=104
add disabled=no ports=ether14 switch=switch2 vlan-id=107
add address=192.168.106.1/27 disabled=no interface=wlan1 network=\
    192.168.106.0
add address=192.168.105.1/27 disabled=no interface=bonding1 network=\
    192.168.105.0
add address=192.168.104.1/27 disabled=no interface=bridge_VoIP network=\
    192.168.104.0
add address=192.168.103.1/27 disabled=no interface=bonding1 network=\
    192.168.103.0
add address=192.168.102.1/27 disabled=no interface=bonding1 network=\
    192.168.102.0
add address=192.168.101.1/27 disabled=no interface=bonding1 network=\
    192.168.101.0
add address=192.168.101.1/32 disabled=no interface=bonding1 network=\
    192.168.101.1
add address=192.168.99.1/27 comment="Internal VLAN" disabled=no interface=\
    bonding1 network=192.168.99.0
add address=192.168.107.1/27 disabled=no interface=bridge_other network=\
    192.168.107.0
/ip arp
add address=192.168.106.2 disabled=no interface=wlan1 mac-address=\
    XX:XX:XX:XX:XX:XX
add address=192.168.105.2 disabled=no interface=bonding1 mac-address=\
    XX:XX:XX:XX:XX:XX
add address=192.168.103.10 disabled=no interface=bonding1 mac-address=\
    XX:XX:XX:XX:XX:XX
add address=192.168.104.3 disabled=no interface=bridge_VoIP mac-address=\
    XX:XX:XX:XX:XX:XX
add address=192.168.101.2 disabled=no interface=bonding1 mac-address=\
    XX:XX:XX:XX:XX:XX
add address=192.168.102.10 disabled=no interface=bonding1 mac-address=\
    XX:XX:XX:XX:XX:XX
add address=192.168.101.9 disabled=no interface=bonding1 mac-address=\
    XX:XX:XX:XX:XX:XX
add address=192.168.104.2 disabled=no interface=bridge_VoIP mac-address=\
    XX:XX:XX:XX:XX:XX
/ip dhcp-client
add add-default-route=yes default-route-distance=0 disabled=no interface=\
    ether10 ipv4=yes ipv6-pd=no use-peer-dns=yes use-peer-ntp=yes
/ip neighbor discovery
set wlan1 disabled=no
set ether10 disabled=no
set ether11 disabled=no
set ether12 disabled=no
set ether13 disabled=no
set ether14 disabled=no
set ether15 disabled=no
set ether16 disabled=no
set ether17 disabled=no
set ether18 disabled=no
set VL-101 disabled=no
set VL-102 disabled=no
set VL-103 disabled=no
set VL-104 disabled=no
set VL-105 disabled=no
set VL-106 disabled=no
set Default disabled=no
set bonding1 disabled=no
set VL-200 disabled=no
set bridge_VoIP disabled=no
set VL-107 disabled=no[/quote]
