I have a problem accessing LAN resources on VLAN interfaces with PPTP VPN client set up as it seems like that all traffics are to be routed through the VPN tunnel. Could anyone please tell me that how to configure the settings by commands so that I can access to my LAN resources over the VLAN interfaces while the VPN is connected?
Below is how I configured the VPN over the VLAN:
- Network Conditions:
Clients are connected on a switch which routes to ether2-master on a Mikrotik router for network access as ether1 is for PPPoE client connection. While no VLAN ID is specified, clients will get IPv4 addresses from 192.168.2.0/24 subnet. Here you can see much clearer details below:
ether2-master without VLAN ID: 192.168.2.0/24
VLAN on ether2-master: 100.64.0.0/10
PPTP VPN Assigned IP Address: 10.0.0.0/24
- Configuration Steps:
i} Set up VLAN and bridge it to change its MAC address.
/interface vlan
add arp=enabled disabled=no interface=ether2-master mtu=1500 name=vlan1 vlan-id=2
add address=100.75.15.1/24 network=100.75.15.0 interface=vlan1
add name=vlan1_pool ranges=100.75.15.2-100.75.15.254
add name=vlan1_dhcp interface=vlan1 address-pool=vlan1_pool disabled=no
add address=100.75.15.0/24 gateway=100.75.15.1 netmask=24 dns-server=208.67.222.222,208.67.220.220
add name=bridge1 admin-mac=60:18:2E:D0:3F:02 auto-mac=no disabled=no
add bridge=bridge1 interface=vlan1 disabled=no
set vlan1_dhcp interface=bridge1
ii) Enable access to 192.168.2.0/24 subnet on VLAN
add chain=srcnat action=masquerade to-addresses=0.0.0.0 src-address=192.168.2.0/24
add chain=srcnat action=masquerade to-addresses=0.0.0.0 src-address=100.64.0.0/10
→ Now I can access LAN resources over the VLAN with different MAC addresses.
iii) Configure PPTP VPN client on VLAN
/interface pptp-client
add name=Office_Access connect-to=1.2.3.4 user=Andy password=thisisthepassword disabled=no
add chain=srcnat out-interface=Office_Access action=masquerade
/ip firewall mangle
add chain=prerouting src-address=100.75.15.2-100.75.15.254 action=mark-routing new-routing-mark=Office_Access
add dst-address=0.0.0.0/0 gateway=Office_Access routing-mark=Office_Access
→ Now I can no longer access LAN resources over the VLAN though the VPN access is now available directly with just the correct VLAN ID settings.
Could anyone please help me with the issue by telling me commands of what to do next?
Thanks! Much appreciated!
Regards,
Andy
