Unbrick 750GL - Help needed please
Hi everyone,
I’ve got a couple of Mikrotik devices which I am trying to unbrick, my 750GL being one of them.
I have netinstall running, computer on IP 192.168.88.2 and netinstall set to allocate IP 192.168.88.1, I’ve downloaded routeros-mipsbe.npk (and all of the other available router packages) and I have wireshark running. I hold the reset button down, it requests and is allocated an IP via bootp, and then it requests vmlinux using tftp. I see a bunch of ETHERNET FRAME CHECK SEQUENCE INCORRECT messages in wireshark, but the file seems to transfer ok. After that, I get absolutely nothing, no further packets from the router at all, my PC tries a few ARP requests which go unanswered, ping fails and it does not show up in netinstall. Is there something I’m doing wrong, something else I can try, or could it be a hardware fault?
Close any other application,
disable any network interface leave enabled only ethernet.
Thanks for the reply, I’ve just given this a try, closing all applications and still the same behaviour on a couple of different host PCs. Any other suggestions?
And also, thank you for replying on my other thread for the RB951G
Which seguence are you using on the device? There is 2 Mode to boot in NetInstall mode.
Trying factory defaults (push reset button for 20 second after it is swtiched on) after 5 minutes push the reset button for 60 second and wait 5 minutes
Method 1
After this:
Plug off Power
Push and hold reset hole
Plug on power
Wait 20sec until ACT stop to BLINK [Like this https://www.youtube.com/watch?v=GIijZ6_i55g]
Method 2
After this:
Plug off Power
Plug on power
Wait 50sec until ACT stop to BLINK.
Let me know!
