Understand firewall filter rules
since 3 years I use a Mikrotik router to connect to the internet by a ADSL pppoe connection. So I am very happy with the setup and the very good working QoS for VoIP. Since a few days I try to set up a port forwarding to my NAS with OpenVPN server, but I am not sure if I did it in a right way.
Setup:
ISP ----- ADSL Modem ------- RB750G (pppoe ether1); 10.0.0.1 local lan ether2-5 ------ NAS with VPN server (10.0.0.113, udp 1194)
I set up a dest-nat like described in the wiki (at the moment disabled)
[admin@MikroTik] /ip firewall nat> print
 0   chain=srcnat action=masquerade src-address=10.0.0.0/24
 1 X ;;; rules for openVPN connection to Diskstation
     chain=dstnat action=dst-nat to-addresses=10.0.0.113 to-ports=1194 protocol=udp dst-address=92.194.50.154 dst-port=1194
 2 X chain=dstnat action=dst-nat to-addresses=10.0.0.113 to-ports=1194 protocol=udp in-interface=pppoe-ether1 dst-port=1194
but there is no connection possible due to my firewall filter rules, I copied this rules here from a thread, but did not really understand what they are doing. So in my opinion a rule like number 9 should do the forwarding, but is it secure, or do I open a securty hole by such a additional filter rule. I did not relay understand how the rules here working and what is really necessary.
[admin@MikroTik] /ip firewall filter> print
 0   ;;; default configuration
     chain=input action=accept protocol=icmp
 1   ;;; default configuration
     chain=input action=accept connection-state=established in-interface=ether1-gateway
 2   ;;; default configuration
     chain=input action=accept connection-state=related in-interface=ether1-gateway
 3   ;;; default configuration
     chain=input action=drop in-interface=ether1-gateway
 4   chain=input action=accept connection-state=established
 5   chain=input action=accept connection-state=related
 6   chain=input action=drop connection-state=invalid
 7   chain=input action=accept in-interface=ether2-local-master
 8   chain=input action=drop
 9 X ;;; filter rule for OpenVPN connection to Diskstation
     chain=forward action=accept protocol=udp dst-port=1194
10   chain=forward action=accept connection-state=established
11   chain=forward action=accept connection-state=related
12   chain=forward action=drop connection-state=invalid
13   chain=forward action=accept in-interface=ether2-local-master
14   chain=forward action=drop
15   ;;; Block all access to the winbox - except to support list # DO NOT ENABLE THIS RULE BEFORE ADD YOUR SUBNET IN THE SUPPORT ADDRESS LIST
     chain=input action=drop protocol=tcp src-address-list=!support dst-port=8291
Thanks for helping
Regards Markus
IP Firewall Filter #9 should read:
chain=forward action=accept protocol=udp dst-address=10.0.0.113 in-interface=pppoe-ether1 dst-port=1194
And rule #2 in NAT should be removed. Rule #1 is fine.
Hope this works,
Tony
Hi Tony,
thanks for your answer, so I changed my filter rule.
By the NAT rule I posted accidentally two versions, so the #1 was only for testing, I have a dialup connection with changing IP every 24 hours, is the a possibility to get the current dailup IP in the rule?
Regards Markus
I don’t think there is a way to do this without setting up a script, due to the way that the NAT rules work. There are, however, quite a lot of good examples in the scripting section of the forum, and if you ask nicely, someone may even help by making one for you. I would recommend trying for yourself though, as it is quite easy to learn and can come in handy in the future.
Tony
