Is not one “Unexpected behavior”, it is always idiotic to call variables with the same name as fields, and this is true in all programming languages(*).
# code not fixed / optimized, except for the variable name
:put ("HARDCODED: " . [/ip firewall filter find comment="The unique comment"])
:local notanidioticname "The unique comment"
:put ("VIA VAR: " . [/ip firewall filter find comment=$notanidioticname])
comment=$comment
is like
“where item comment is = to the (same) item comment”, and obviously is true for all items, so all items are returned.
the_parameter = "value"
def the_method(the_parameter):
print(f"Value is: {the_parameter}")
the_method(the_parameter=the_parameter)
Ruby:
puts "Value is: #{the_parameter}"
end
the_method(the_parameter: the_parameter)
Kotlin:
fun theMethod(theParameter: String) {
println("Value is: $theParameter")
val theParameter = "value"
fun main() {
theMethod(theParameter = theParameter)
C#:
using System;
class Program {
static void Main() {
string theParameter = "value";
TheMethod(theParameter: theParameter);
static void TheMethod(string theParameter) {
Console.WriteLine($"Value is: {theParameter}");
Swift:
func theMethod(theParameter: String) {
print("Value is: \(theParameter)")
let theParameter = "value"
theMethod(theParameter: theParameter)
PHP:
function theMethod($theParameter) {
echo "Value is: $theParameter";
$theParameter = "value";
theMethod(theParameter: $theParameter);
Scala:
object Main extends App {
def theMethod(theParameter: String): Unit = {
println(s"Value is: $theParameter")
PowerShell:
function TheMethod {
param([string]$theParameter)
Write-Host "Value is: $theParameter"
TheMethod -theParameter $theParameter
(defun the-method (&key the-parameter)
(format t "Value is: ~A~%" the-parameter))
(let ((the-parameter "value"))
(the-method :the-parameter the-parameter))
Ada:
with Ada.Text_IO; use Ada.Text_IO;
procedure Main is
the_parameter : String := "value";
procedure The_Method (the_parameter : String) is
begin
Put_Line ("Value is: " & the_parameter);
end The_Method;
begin
The_Method (the_parameter => the_parameter);
end Main;
All seem to work just fine... But I guess, you learn something new every day
LOL, Lisp and Ada examples. Now, RouterOS’s logic inherits some from LUA actually, which ver 5(?) supported. I think they created the current language to be more “config centric” than a general-purpose language. All this still has to fit in 16MB flash disks…
If you think all commands are functions, the restriction makes more sense. In a routeros function, named parameters become local variables. So when [find] “function” executes, it has a local $address inside it. And same happens with user functions:
I see, thank you for the insight. I’ll be extra careful in future and be aware of the scopes/overshadowing behavior - one can easily shoot themselves in the foot because of all of this.
internal code for /ip add find where address=$address
(eval /ip address find
where=$address;$network;$netmask;$broadcast;$interface;$actual-interface;$invalid;$dynamic;$disabled;$comment;$.id;$.nextid;$.dead;(= $address $address);5) (= item1 item2) is a function that return true is both item have same value.
In this case (= $address $address), so the function return true everytime for obvious reason.
internal code for /ip add find where address=$xxx
where=$address;$network;$netmask;$broadcast;$interface;$actual-interface;$invalid;$dynamic;$disabled;$comment;$.id;$.nextid;$.dead;(= $address $xxx);5)
This time the address is really compared with $xxx that do not exist in this ambit and is searched on local (then global if not finded) variables.
