Unexpected MSTI bridge ID?
Don’t have much experience with MSTP. Seeing some strange output.
Switch 1 looks fine.
> interface/bridge/print
Flags: D - dynamic; X - disabled, R - running
 0  R name="bridge" mtu=auto actual-mtu=1500 l2mtu=1584 arp=enabled arp-timeout=auto
      mac-address=78:9A:18:3A:04:CB protocol-mode=mstp fast-forward=yes igmp-snooping=no auto-mac=no
      admin-mac=78:9A:18:3A:04:CB ageing-time=5m priority=0x8000 max-message-age=20s forward-delay=15s
      transmit-hold-count=6 region-name="" region-revision=0 max-hops=20 vlan-filtering=yes
      ether-type=0x8100 pvid=1 frame-types=admit-all ingress-filtering=yes dhcp-snooping=no
      port-cost-mode=long mvrp=no max-learned-entries=auto
> interface/bridge/msti/monitor 1
                    state: enabled
               identifier: 2
      current-mac-address: 78:9A:18:3A:04:CB
                bridge-id: 0x8000.78:9A:18:3A:04:CB
              root-bridge: yes
  regional-root-bridge-id: 0x8002.78:9A:18:3A:04:CB
           root-path-cost: 0
                root-port: none
               port-count: 25
    designated-port-count: 7
Why does switch 2 get the same MAC address/bridge ID? Consequently, they both think they are the root bridge?
      mac-address=78:9A:18:12:C8:70 protocol-mode=mstp fast-forward=yes igmp-snooping=no auto-mac=no
      admin-mac=78:9A:18:12:C8:70 ageing-time=5m priority=0x8000 max-message-age=20s forward-delay=15s
                    state: enabled
               identifier: 2
              root-bridge: yes
           root-path-cost: 0
                root-port: none
               port-count: 25
    designated-port-count: 6
Did you copy the config of switch 1 to switch 2?
Can you share both configs?
/export file=anynameyoulike
Remove serial and any other private info, post as Preformatted text by using the </> button.
Sure.
S1
# 2026-02-17 16:46:50 by RouterOS 7.20.8
# model = CRS326-24S+2Q+
/interface bridge add admin-mac=78:9A:18:3A:04:CB auto-mac=no name=bridge protocol-mode=mstp vlan-filtering=yes
/interface ethernet set [ find default-name=sfp-sfpplus1 ] comment=HV1
/interface ethernet set [ find default-name=sfp-sfpplus2 ] comment=HV2
/interface ethernet set [ find default-name=sfp-sfpplus3 ] comment=HV3
/interface ethernet set [ find default-name=sfp-sfpplus4 ] comment=HV4
/interface ethernet set [ find default-name=sfp-sfpplus5 ] disabled=yes
/interface ethernet set [ find default-name=sfp-sfpplus6 ] disabled=yes
/interface ethernet set [ find default-name=sfp-sfpplus7 ] disabled=yes
/interface ethernet set [ find default-name=sfp-sfpplus8 ] disabled=yes
/interface ethernet set [ find default-name=sfp-sfpplus9 ] disabled=yes
/interface ethernet set [ find default-name=sfp-sfpplus10 ] disabled=yes
/interface ethernet set [ find default-name=sfp-sfpplus11 ] disabled=yes
/interface ethernet set [ find default-name=sfp-sfpplus12 ] disabled=yes
/interface ethernet set [ find default-name=sfp-sfpplus13 ] disabled=yes
/interface ethernet set [ find default-name=sfp-sfpplus14 ] disabled=yes
/interface ethernet set [ find default-name=sfp-sfpplus15 ] disabled=yes
/interface ethernet set [ find default-name=sfp-sfpplus16 ] disabled=yes
/interface ethernet set [ find default-name=sfp-sfpplus17 ] disabled=yes
/interface ethernet set [ find default-name=sfp-sfpplus18 ] disabled=yes
/interface ethernet set [ find default-name=sfp-sfpplus19 ] disabled=yes
/interface ethernet set [ find default-name=sfp-sfpplus21 ] disabled=yes
/interface ethernet set [ find default-name=sfp-sfpplus22 ] disabled=yes
/interface vlan add interface=ether1 name=MGMT vlan-id=5
/interface bonding add lacp-rate=1sec mlag-id=10 mode=802.3ad name=mlag-hv1 slaves=sfp-sfpplus1
/interface bonding add lacp-rate=1sec mlag-id=20 mode=802.3ad name=mlag-hv2 slaves=sfp-sfpplus2
/interface bonding add lacp-rate=1sec mlag-id=30 mode=802.3ad name=mlag-hv3 slaves=sfp-sfpplus3
/interface bonding add lacp-rate=1sec mlag-id=40 mode=802.3ad name=mlag-hv4 slaves=sfp-sfpplus4
/interface bonding add lacp-rate=1sec mlag-id=1 mode=802.3ad name=mlag-rt11 slaves=sfp-sfpplus23
/interface bonding add lacp-rate=1sec mlag-id=2 mode=802.3ad name=mlag-rt12 slaves=sfp-sfpplus24
/interface bonding add mode=802.3ad name=qsfp slaves=qsfpplus1-1,qsfpplus1-2,qsfpplus1-3,qsfpplus1-4,qsfpplus2-1,qsfpplus2-2,qsfpplus2-3,qsfpplus2-4
/interface list add name=NEIGHBOR_DISCOVERY
/interface list add name=OOB
/interface list add name=K2
/port set 0 name=serial0
/user group add name=backup policy=ssh,ftp,read,write,policy,test,sniff,sensitive,api,!local,!telnet,!reboot,!winbox,!password,!web,!romon,!rest-api
/interface bridge mlag set bridge=bridge peer-port=qsfp priority=64
/interface bridge msti add bridge=bridge identifier=2 vlan-mapping=19
/interface bridge port add bridge=bridge disabled=yes frame-types=admit-only-vlan-tagged interface=sfp-sfpplus1 pvid=999
/interface bridge port add bridge=bridge disabled=yes frame-types=admit-only-vlan-tagged interface=sfp-sfpplus2 pvid=999
/interface bridge port add bridge=bridge disabled=yes frame-types=admit-only-vlan-tagged interface=sfp-sfpplus3 pvid=999
/interface bridge port add bridge=bridge disabled=yes frame-types=admit-only-vlan-tagged interface=sfp-sfpplus4 pvid=999
/interface bridge port add bridge=bridge frame-types=admit-only-vlan-tagged interface=sfp-sfpplus5 pvid=999
/interface bridge port add bridge=bridge frame-types=admit-only-vlan-tagged interface=sfp-sfpplus6 pvid=999
/interface bridge port add bridge=bridge frame-types=admit-only-vlan-tagged interface=sfp-sfpplus7 pvid=999
/interface bridge port add bridge=bridge frame-types=admit-only-vlan-tagged interface=sfp-sfpplus8 pvid=999
/interface bridge port add bridge=bridge frame-types=admit-only-vlan-tagged interface=sfp-sfpplus9 pvid=999
/interface bridge port add bridge=bridge frame-types=admit-only-vlan-tagged interface=sfp-sfpplus10 pvid=999
/interface bridge port add bridge=bridge frame-types=admit-only-vlan-tagged interface=sfp-sfpplus11 pvid=999
/interface bridge port add bridge=bridge frame-types=admit-only-vlan-tagged interface=sfp-sfpplus12 pvid=999
/interface bridge port add bridge=bridge frame-types=admit-only-vlan-tagged interface=sfp-sfpplus13 pvid=999
/interface bridge port add bridge=bridge frame-types=admit-only-vlan-tagged interface=sfp-sfpplus14 pvid=999
/interface bridge port add bridge=bridge frame-types=admit-only-vlan-tagged interface=sfp-sfpplus15 pvid=999
/interface bridge port add bridge=bridge frame-types=admit-only-vlan-tagged interface=sfp-sfpplus16 pvid=999
/interface bridge port add bridge=bridge frame-types=admit-only-vlan-tagged interface=sfp-sfpplus17 pvid=999
/interface bridge port add bridge=bridge frame-types=admit-only-vlan-tagged interface=sfp-sfpplus18 pvid=999
/interface bridge port add bridge=bridge frame-types=admit-only-vlan-tagged interface=sfp-sfpplus19 pvid=999
/interface bridge port add bridge=bridge frame-types=admit-only-vlan-tagged interface=sfp-sfpplus20 pvid=999
/interface bridge port add bridge=bridge frame-types=admit-only-vlan-tagged interface=sfp-sfpplus21 pvid=999
/interface bridge port add bridge=bridge frame-types=admit-only-vlan-tagged interface=sfp-sfpplus22 pvid=999
/interface bridge port add bridge=bridge disabled=yes frame-types=admit-only-vlan-tagged interface=sfp-sfpplus23 pvid=999
/interface bridge port add bridge=bridge disabled=yes frame-types=admit-only-vlan-tagged interface=sfp-sfpplus24 pvid=999
/interface bridge port add bridge=bridge frame-types=admit-only-vlan-tagged interface=qsfp pvid=999
/interface bridge port add bridge=bridge frame-types=admit-only-vlan-tagged interface=mlag-hv4 pvid=999
/interface bridge port add bridge=bridge frame-types=admit-only-vlan-tagged interface=mlag-hv1 pvid=999
/interface bridge port add bridge=bridge frame-types=admit-only-vlan-tagged interface=mlag-hv2 pvid=999
/interface bridge port add bridge=bridge frame-types=admit-only-vlan-tagged interface=mlag-hv3 pvid=999
/interface bridge port add bridge=bridge frame-types=admit-only-vlan-tagged interface=mlag-rt11 pvid=999
/interface bridge port add bridge=bridge frame-types=admit-only-vlan-tagged interface=mlag-rt12 pvid=999
/ip neighbor discovery-settings set discover-interface-list=NEIGHBOR_DISCOVERY protocol=lldp
/interface bridge vlan add bridge=bridge tagged=mlag-rt11,mlag-rt12,qsfp,K2 vlan-ids=20-29
/interface bridge vlan add bridge=bridge tagged=sfp-sfpplus20,mlag-rt11,mlag-rt12,qsfp,K2 vlan-ids=9
/interface bridge vlan add bridge=bridge tagged=mlag-rt11,mlag-rt12,qsfp,K2 vlan-ids=19
/interface list member add interface=bridge list=NEIGHBOR_DISCOVERY
/interface list member add interface=mlag-hv4 list=K2
/interface list member add interface=mlag-hv1 list=K2
/interface list member add interface=mlag-hv2 list=K2
/interface list member add interface=mlag-hv3 list=K2
/ip address add address=10.7.5.111/24 interface=MGMT network=10.7.5.0
/ip cloud set update-time=no
/ip dns set servers=8.8.8.8,1.1.1.1
/ip route add gateway=10.7.5.101
/ip service set ftp disabled=yes
/ip service set telnet disabled=yes
/ip service set www disabled=yes
/ip service set api-ssl disabled=yes
/ip ssh set strong-crypto=yes
/snmp set enabled=yes
/system clock set time-zone-autodetect=no time-zone-name=Europe/Stockholm
/system logging add disabled=yes topics=stp
/system ntp client set enabled=yes
/system ntp client servers add address=10.7.5.101
/system package update set channel=long-term
/system routerboard settings set auto-upgrade=yes enter-setup-on=delete-key
/tool mac-server set allowed-interface-list=none
/tool mac-server mac-winbox set allowed-interface-list=OOB
/tool mac-server ping set enabled=no
S2
# 2026-02-17 16:46:54 by RouterOS 7.20.8
/interface bridge add admin-mac=78:9A:18:12:C8:70 auto-mac=no name=bridge protocol-mode=mstp vlan-filtering=yes
/interface ethernet set [ find default-name=sfp-sfpplus20 ] disabled=yes
/interface vlan add interface=bridge name=VM vlan-id=23
/interface bridge port add bridge=bridge disabled=yes interface=sfp-sfpplus1
/interface bridge port add bridge=bridge disabled=yes interface=sfp-sfpplus2
/interface bridge port add bridge=bridge disabled=yes interface=sfp-sfpplus3
/interface bridge port add bridge=bridge disabled=yes interface=sfp-sfpplus4
/interface bridge port add bridge=bridge interface=sfp-sfpplus5
/interface bridge port add bridge=bridge interface=sfp-sfpplus6
/interface bridge port add bridge=bridge interface=sfp-sfpplus7
/interface bridge port add bridge=bridge interface=sfp-sfpplus8
/interface bridge port add bridge=bridge interface=sfp-sfpplus9
/interface bridge port add bridge=bridge interface=sfp-sfpplus10
/interface bridge port add bridge=bridge interface=sfp-sfpplus11
/interface bridge port add bridge=bridge interface=sfp-sfpplus12
/interface bridge port add bridge=bridge interface=sfp-sfpplus13
/interface bridge port add bridge=bridge interface=sfp-sfpplus14
/interface bridge port add bridge=bridge interface=sfp-sfpplus15
/interface bridge port add bridge=bridge interface=sfp-sfpplus16
/interface bridge port add bridge=bridge interface=sfp-sfpplus17
/interface bridge port add bridge=bridge interface=sfp-sfpplus18
/interface bridge port add bridge=bridge interface=sfp-sfpplus19
/interface bridge port add bridge=bridge interface=sfp-sfpplus20
/interface bridge port add bridge=bridge interface=sfp-sfpplus21
/interface bridge port add bridge=bridge interface=sfp-sfpplus22
/interface bridge port add bridge=bridge disabled=yes interface=sfp-sfpplus23
/interface bridge port add bridge=bridge disabled=yes interface=sfp-sfpplus24
/interface bridge port add bridge=bridge interface=qsfp
/interface bridge port add bridge=bridge interface=mlag-hv4
/interface bridge port add bridge=bridge interface=mlag-hv1
/interface bridge port add bridge=bridge interface=mlag-hv2
/interface bridge port add bridge=bridge interface=mlag-hv3
/interface bridge port add bridge=bridge interface=mlag-rt11
/interface bridge port add bridge=bridge interface=mlag-rt12
/interface bridge vlan add bridge=bridge tagged=mlag-rt11,mlag-rt12,qsfp,K2 vlan-ids=9,11-29
/ip address add address=10.7.5.112/24 interface=MGMT network=10.7.5.0
/ip address add address=10.7.23.5/24 interface=VM network=10.7.23.0
There are a couple more devices participating in the spanning tree. They both get the same root bridge ID, but their own, expected bridge ID.
Edit: I see that all the MSTP bridge IDs are shown as 0x8000. Isn’t that supposed to be 0x8002?
The unexpected bridge ID is probably due to MLAG, come to think of it.
