Im having connectivitie issue in my network (some hosts kan ping an IP others cant) and i just found out that the issue is due to the Unicast FDB being incorrect
I have had a static entry in the past, but it look like this is still giving issues
[admin@sw05] /interface ethernet switch unicast-fdb> print
Flags: X - disabled, I - invalid, D - dynamic, A - active
# MAC-ADDRESS PORT VLAN-ID ACTION MIRROR SVL AGE ISOLATION-PROFILE QOS-GROUP
0 DA 4C:5E:0C:00:85:D3 switch1-cpu 0 forward no yes 3 promiscuous none
1 DA 3C:D9:2B:06:CD:EA ether21-PP07-MicroServ... 110 forward no no 3 promiscuous none
The mac adres on interface ether21 is not there, it is on a different Mikrotik infact however it was a static entry in the past. The static entry is gone, but the switchchip does not agree. I cannot flush the entry as it return right away. I therefore cannot at a static entry to the correct interface as a work arround.
- I disabled the interface
- I have removed the master interface (RouterOS v6.40.4)
