Hi all,
I’m getting this error (unicast key exchange timeout) when i trying to associate a windows (W7) client to my RB133 5.11 with an Atheros AR5212.
If I disable the security WPA2 i can connect perfectly fine..
I saw this kind of errors as a common BUG with the version 3.X
I was assuming it got solved…am I right?
Here’s my conf. which intend to be a simple wireless AP…
wireless
name=“wlan2” mtu=1500 mac-address=00:11:F5:4B:BA:4A arp=enabl
interface-type=Atheros AR5212 mode=ap-bridge ssid=“MikroTik”
frequency=2412 band=2ghz-b channel-width=20mhz scan-list=defa
wireless-protocol=802.11 antenna-mode=ant-a wds-mode=disabled
wds-default-bridge=none wds-ignore-ssid=no bridge-mode=enable
default-authentication=yes default-forwarding=yes default-ap-
default-client-tx-limit=0 hide-ssid=no security-profile=profi
compression=no
sec profile
name=“profile1” mode=dynamic-keys authentication-types=wpa2-psk
unicast-ciphers=aes-ccm group-ciphers=aes-ccm wpa-pre-shared-key=“kokoloko”
wpa2-pre-shared-key=“kokoloko” supplicant-identity=“” tls-mode=no-certificates
tls-certificate=none static-algo-0=none static-key-0=“” static-algo-1=none
static-key-1=“” static-algo-2=none static-key-2=“” static-algo-3=none
static-key-3=“” static-transmit-key=key-0 static-sta-private-algo=none
static-sta-private-key=“” radius-mac-authentication=no radius-mac-accounting=no
radius-eap-accounting=no interim-update=0s radius-mac-format=XX:XX:XX:XX:XX:XX
radius-mac-mode=as-username radius-mac-caching=disabled group-key-update=5m
management-protection=disabled management-protection-key=“”
logs:
wireless,info debug: 00:0E:9B:6B:71:B8@wlan2: connected
15:53:35 wireless,info 00:0E:9B:6B:71:B8@wlan2: disconnected, unicast key exchange
timeout
this is happening in an endless loop
can any body help me and tell me what I’m doing wrong here?
any help will be highly appreciated
