hello,
i bought last eeb a metal 5shpn it is an acces point.
i’ve always same problem like insubject:
“unicast key exchange timeout”.
i try to setup security profile in wpa psk, wpa2 psk …
but nothing probable routeros issue??
wath you can suggest me
tnks in addance
ps. i alredy send email to mikrotik technical support awaiting answer.
The problem are on aes-ccm unicast key exchange timeout, set group key timeout more than the default 5 min.
If you want solve this problem, use only MikroTik hardware and do not mix.
