UNICAST/MULTICAST over the internet
hi,
i have bought myself a C-tuner box to IP box. I need to establish an VPN connection or something like that. but i can’t seem to figure how to route multicast and unicast over VPN. So plz does anyone how to make this work
my C-tuner box is behind a mikrotik RB1200 router and the end is Mikrotik RB2011ILS
Use a GRE tunnel interface, and then activate PIM on the two routers. Choose one of them to be the rendezvous point and configure both to use the exact same IP address as the RP for the group your application uses (or all groups if you like things simple).
Static routes at both ends should be all you need for unicast. Also make sure that your masquerade don’t NAT traffic going across the VPN.
