Unified AP keep loosing internet connection
We have 2 Unified access Points that are connected to the mikrotik router. From time to time, they keep loosing connection to the internet but once I restart the router They are ok for a while. The APs are on static IP and working ok. If i change the router and use TP Link the APs work fine. Kindly what could be the issue?
Have you looked at the routerboard logs?
What’s the RouterOS version? What’s the System > Routerboard Current/Upgrade Firmware?
What’s the Routerboard model?
There is nothing unusual on the logs.
Model 1100AHx2
firmware 3.24
What do you mean nothing unusual? If there was an interruption, it was logged. If not, your WiFi AP device could be malfunctioning.
It doesn’t show that the APs are disconnected or any error.
I have changed the APs severally buts till the same issue
