Uninstalling Packages OS 4.10
I cannot get system package uninstall to work on 4.10. I looked at the HDD space on my 433, and saw 30Mb free, so I thought I would load Dude 3.6.npk (8.9Mb). Now have 0Mb free HDD, and setting uninstall via Winbox or terminal, or trying via Dude to schedule uninstall, nothing works, all packages remain. I tried to disable packages first, also no success.
Is this a bug, or am I missing something?
Brian
You need to free up hard drive space to uninstall the packages. Try removing some firewall/mangle rules or layer 7 filters.
Thanks, will do that and report…
Yes, thanks, that worked perfectly. Cleared about 1.2M and then rebooted, all scheduled un-installs took place as they should.
Regards
Brian
