Hi people, Can someone help me?
I’m new user here in the mikrotik forum and I would like a help with my project. I have a doubt about the HOTSPOT in mikrotik. Below, I create a small example to ilustrate it.
I would like to know if it’s possible to create a unique HOTSPOT in the “MIKROTIK A” using several VLANs and one Ethernet port. For each VLAn, I would like to use a specific IP address, therefore I will use one DHCP server for each one.
The cause for this, is separate all network to aggregate more security and isolate the broadcast in each network.
I would like to isolate the access, for example, when the user is connected in VLAN B and try to ping VLAN A is not possible because are different VLANs.
In attached I’m sending the PDF File with my project.
Thanks a lot.
cadamuroA
Hotspot.pdf (249 KB)
