Unlimited queues not counting anymore?
Hi there!
I’ve been using queues with NO bandwidth limitation for a long time now to create graphs and count rx/tx and total rx/total tx. On Friday I would have needed this feature on a RB450 with 3.18 but it didn’t count anything! After upgrading the FW an ROS to the most current version I still have the same problem! As soon as I enter a bandwidth limitation the queue starts to count, which proves to me that the queue is correct.
No more counting on unlimited queues… Is this a bug or a “feature”?
Greets,
uebi
change queue-type from default-small to default.
Sometimes life’s so easy…
THX!
Greets,
uebi
PS: Just checked it again and I got a 2.9.25 x86 installation where default-small on unlimited queues actually IS counting. Why did it work in the past, will it work in the future and why was there this change??
Greets,
uebi
If I remember correctly these changes were added in v3.13 to fix problems with simple queues crashing routers.
Oh, I see, thanks for the info!
Greets,
uebi
