When I create a file to enter data, regularly via a task scheduler (10 min) I have no problem.
When I restart the RB750 v3 via Winbox, my file is correct with the data I entered previously.
On the other hand, if there is a power failure, or if I unplug the RB750 v3, the file is at 0.
Why ?
Script 1 : statistique_queue
:global newFileContents "";
:global traf;
:global namevlan;
:global megsu "0";
:global megsd "0";
:global resulter " ";
:global logmsg;
:global datum [/system clock get date];
:global vrijeme [/system clock get time];
:global filenamess;
#:put "$datum - $vrijeme";
/queue tree
:foreach o in=[/queue tree find] do={
:set traf [get $o bytes];
:if ($traf > 0) do={
:set logmsg "";
:set namevlan [get $o value-name=name];
:set megsd ($traf / 1024 / 1024)
#:put "$namevlan : $megsd Mo";
:set newFileContents ($newFileContents . $datum . ";" . $vrijeme . ";" . $namevlan . ";" . $megsd . ";" ."Mo\n");
/file print file=$filenamess;
:delay 2;
/file set $filenamess contents=$newFileContents;
Script 2 : onstartscript
:global basefilename test;
:local filenamess test;
:local tmp test;
:local count 0;
:while ([:len [/file find name="$filenamess".".txt"]] > 0) do={
:set filenamess ($basefilename.$count);
:set tmp ($basefilename.$count);
:set count ($count +1);
:global filenamess $tmp;
:put $filenamess;
Schedule schedule1 (on start)
/system scheduler disable schedule2
:delay 120;
/system script run onstartscript
/system scheduler enable schedule2
Schedule schedule2 (10 min)
/system script run statistique_queue
Best regards.
