unpluged problem
Dear sir
my problme it that , if i unplugged the cable from mikrotik server in running possition. After plugging the cable the user is showing running possition and also session is running.
ple. solve it or give me process for that
thanks
sandip
Hello friend
have to check profile interface, not more time for item ‘keepalive-timeout’.
regards
Hasbullah.com
but if i unpluged the cable yesterday and pluged after 20 minutes , then the session of previous running user is showing running today. what is this ?
i also set keepalive time - 00:02:00,
ple solved or give me suggesion for that
thanks
sandip
yup…
copy than paste here for your config…
maybe i will help you or other person
regards
Hasbullah.com
