unset log and log-prefix in firewall
sorry for a maybe stupid question - but is it possible to completely unset log and log-prefix in a firewall rule?
/ip firewall filter unset 6 log
doesn’t work, it always ends up with a
input does not match any value of value-name
Of course I can set the values to no and “” respectively, but that still clutters the listing. Is there a way to completely remove these two parameters? Seems they are excluded from unset…
Thanks,
Florian
I’m also wondering this, unset seems to be an intended option but doesn’t work.
set 1 !log
is also suggested in the scripting manual and this also is a syntax error syntax error (line 1 column 7)
Works on 7.12.1:
ip firewall filter set [find comment="drop invalid"] log=no
ip firewall filter set [find comment="drop invalid"] log-prefix=""
Edit: Didn’t read post carefully. “unset” doesn’t list log or log-prefix, alas.
