HI, I have quite unstable ping from client (PC) to mikrotik (AP, routerboard 532, CM9, very good signal (300m/10dB aerials)),channel is used just by me - no interference,5GHz). Another routerboard works with same result(!)
any idea?
thanks for help, Radek
Odpověď od 10.0.0.1: bajty=1400 čas=4ms TTL=63
Odpověď od 10.0.0.1: bajty=1400 čas=49ms TTL=63
Odpověď od 10.0.0.1: bajty=1400 čas=24ms TTL=63
Odpověď od 10.0.0.1: bajty=1400 čas=58ms TTL=63
Odpověď od 10.0.0.1: bajty=1400 čas=74ms TTL=63
Odpověď od 10.0.0.1: bajty=1400 čas=5ms TTL=63
Odpověď od 10.0.0.1: bajty=1400 čas=53ms TTL=63
Odpověď od 10.0.0.1: bajty=1400 čas=64ms TTL=63
In 802.11a, 12 clients connected, some active some passive but all connected. Ping times are consistent for passive clients.
Switch the same to 802.11b, then even the ping times for passive clients fluctuate. Wonder if this is not a technology issue ie DSSS vs OFDM. Not sure, but I suppose 802.11a OFDM can communicate with 4 clients simoultaneously whereas 802.11b DSSS can communicate with only one at a time. Thus, it is more likely for DSSS to show more fluctuation compared to OFDM. In other words, 802.11b is crap… 802.11g does OFDM, anyone tried it for ping times?
Just check, when only one client is active on 802.11b, ping times are consistent unless a queue limit is reached.
I have it! bad latency of ping appears when the client moves from for example 54 to 36 Mbps or any other speed combination. So when the client changes the speed ping latency goes abnormally high. If I set the ap to 802.11b (11Mbps) then ping goes well because clients work on 11 Mbps and not lower (because of better strenght of signal)… well, interesting thing is that the lowcost AP don’t do this…
