Unstable/Unusable 2.4GHz network hAP ax2
the past few days I’ve been searching the web for a solution to my unstable 2.4GHz wifi. I used the Default configuration for my hAP ax2 and everything works except the 2,4GHz wifi. I see it pop up on my phone wifi search every now and then for a minute maybe but its unusable. I’ve played around with some settings (Different Bands, Channel width, Frequency, different security settings) but to no avail. Does anybody have a clue what might cause this unstability? since some of my devices in my Network rely on 2,4GHz.
Nobody has a crystal ball…
Export config, post between code quotes after removing serial number and public wan ip.
Thanks for replying. I’m really new to this so I hope I do this right. This is what I think you mean with config?
# 2023-09-10 16:20:07 by RouterOS 7.11.2
# software id = YH9F-C24M
# model = C52iG-5HaxD2HaxD
# serial number = ###########
add admin-mac=48:A9:8A:95:D2:E1 auto-mac=no comment=defconf name=bridge
/interface wifiwave2
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=\
    10min-cac .width=20/40/80mhz configuration.country=Germany .mode=ap \
    .ssid=MikroTik-95D2E5 disabled=no security.authentication-types=\
    wpa2-psk,wpa3-psk
set [ find default-name=wifi2 ] channel.band=2ghz-ax .frequency=2426-2448 \
    .skip-dfs-channels=10min-cac .width=20mhz configuration.antenna-gain=3 \
    .country=Germany .mode=ap .ssid=MikroTik-95D2E6 .tx-power=0 disabled=no \
    security.authentication-types=wpa2-psk .encryption=""
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
    192.168.88.0
/ip dhcp-client
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
Did you use Winbox for the config ?
On 2GHz interface, check if tab security section encryption is folded in.
Not empty and folded out.
Where does this come from ? Why is this set ?
and
.tx-power=0
Side-comment:
I prefer to set frequency as much as possible manual. Otherwise you never know what will be selected.
On 2GHz channel it is recommended to use the 1/6/11 scheme (2412, 2437, 2462). Nothing else.
If you get on a channel in between, you will get interference from 2 other channels.
yes I used WinBox, I probably folded it open while looking for options for testing. The gain setting I found on the First Time Configuration guide, the tx-power I don’t really know why it is there. If I did it right with the frequencies like this then it sadly is still unstable…
    wpa2-psk,wpa3-psk
set [ find default-name=wifi2 ] channel.band=2ghz-ax .frequency=2412 \
    .secondary-frequency=2437,2462 .skip-dfs-channels=10min-cac .width=20mhz \
    configuration.country=Germany .mode=ap .ssid=MikroTik-95D2E6 disabled=no \
Remove secondary frequency, that’s not the intention to set it there.
Stick to 1 fixed channel first to see if we can get it stable.
Also remove skip dfs on 2ghz interface.
I think I’ve got it stable after I did two things. First remove DFS and secondly, moved the router further away from a grounded heating element into the middle of my room for this test. Seems like one of those things fixed it.
Edit: The heating element is not on, and the router was not intended to stay there for an extended period of time (especially when I gonna start using the heater again)…just felt like I had to mention this.
